SSRS Pack Slip Qty Multiplying by 4
@tmayfield and I found that there was a row in OrderHed_ for each ship dtl line so when joined back to ShipDtl on OrderNum, you’d get 1:M and thus end up with the Summed result that Tammy was questioning.
For now, given they only print one pack at a time and only put one order on a pack, we just made another dataset and queried OrderHed_ and Tammy was happy with First(field,“OrderHed”).
Alternatively Tammy, we could have made a field in the main dataset as (SELECT MIN(OrderHed.AddtlShipContactName_c) FrOM OrderHed_" + Parameters!TableGuid.Value + “) as [Contact Name], (SELECT MIN(OrderHed.AddtlShipPhoneNum_c) FrOM OrderHed_” + Parameters!TableGuid.Value + ") as [addlPhoneNum] and so on and so forth and then you just need to add those fields to your main dataset.
We also talked about using a subquery as well and grouping by all the fields in OrderHed table and then joining that subquery to ShipDtl in the main query.
Many things we could do.
Thank you so much for your help. I owe you a beer at the next Insights we are both at.
