SSRS Page Number not resetting by group
Mr. Jose: Wahoo - it works - thanks for the help.
I had seen and tried the first link you sent - but I did not even consider that I was doing it wrong.  Aaaaaarg!
I did not follow the instructions carefully enough.  I was setting the page break options on the Tablix and NOT on the group.
Once I saw that it all fell into place and the page reset is working great.
You are the man Jose -
Take Care,
DaveO
I am running V10.0.700.4.
When I print my AR Invoice group the page number does not get reset by group (Invoice number).
So If I print an Invoice Group that has 2 invoices the second invoice shows page 2 of 2.
Has anyone been able to fix this yet?
Dave Olender
Ph: 651-246-3281
This is a known issue that Epicor tech support is giving their standard “it will be fixed in the next version”….probably 10.1.
Manasa
Sent: Tuesday, September 08, 2015 12:52 PM
Subject: [Vantage] SSRS Page Number not resetting by group
Dave Olender
Ph: 651-246-3281
IMPORTANT NOTICE FROM API: This communication, including any attachments, contains information that may be confidential or privileged and is intended solely for the entity or individual to whom it is addressed. If you are not the intended recipient, please contact the sender immediately and delete this message. Any unauthorized disclosure, copying or distribution of this message is strictly prohibited.
You can fix this yourself just make a standard forumla that resets on group change.Â
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
On Tue, Sep 8, 2015 at 1:50 PM, Manasa Reddy manasa.reddy@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p>
Manasa
Â
Â
Â
Â
Â
Â
So If I print an Invoice Group that has 2 invoices the second invoice shows page 2 of 2.Â
Â
Â
Â
Dave Olender
Ph: 651-246-3281
</div>
<div style="color:#fff;min-height:0;"></div>
Is this an Epicor issue?
It seems like a Microsoft issue?
If I create a new SSRS independent of Epicor does the page reset work?
DaveO
Between you and Jose if you can figure it out be my guest (and of course I would be grateful)….I am only reporting what I was told by Epicor.  I am not by any means an SSRS guru to say otherwise.
Manasa
Sent: Tuesday, September 08, 2015 2:32 PM
Subject: RE: [Vantage] SSRS Page Number not resetting by group
DaveO
Mr. Jose: Thank you fro the link.
I found the same thread and tried his solution - but it did not work for me.
DaveO
What part didn't work?
Jose C Gomez
Software Engineer
On Tue, Sep 8, 2015 at 2:34 PM, daveolender@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p></p><p>Mr. Jose: Thank you fro the link.</p><p><br></p><p>I found the same thread and tried his solution - but it did not work for me.</p><p><br></p><p>DaveO<br></p><p></p>
</div>
Try this one, though the first link works for me without issue
Jose C Gomez
Software Engineer
Jose C Gomez
Software Engineer
Â
<div>
</div>
Thank you sir - I will give it a try.
DaveO
