I’m trying to add a terms and conditions page to the SSRS PO report, but I’m not having a lot of luck. I’m having issues with the header/footer displaying where it shouldn’t or it printing too early.
Has anyone had any luck doing this? If so, what methods did you take to achieve this?
Mr. Dusty: The Header/Footer areas in SSRS are not “data enabled”.
I have created a row in the PONum group footer and placed my T&C in that one row. You can set the Rectangle property “Add a page break before” so the T&C will always start on a new page. You can then use a formula to suppress your header and footer info for the last page.
Although - this may be a good time to ask - why use a T&C page on your PO’s at all. Almost all companies now have a single sentence that says “Please see http://www.ourcompanyname/TermsAndConditions” (or something similar) instead of a T&C page. It is easier to update and causes less paperwork.
It is also not uncommon to establish a Terms and Conditions Document that is signed by the Vendor acknowleding your T&C.
