I have a calculated field in a footer of the outermost group, that doesn’t render correctly in print layout (see picts below). I’m trying to sequentially number the group footer
The expression of a field above (before and outside) the outermost group is: =code.initLineNum()
the expression of the “Line” field (which is in the outermost groups footer) is =code.myLineNum()
the code for those functions is:
Public dim lineNum as integer
Public Function initLineNum()
lineNum = 0
End Function
Public Function myLineNum() as integer
lineNum = lineNum + 1
Return lineNum
End Function
Below is what I get from SSRS and from E10
Here’s what it looks like when previewing in SSRS Report Builder. This is what I expect.
Here’s what Print Layout looks like in SSRS Report Builder:
And here’s what it looks like when run from E10:
