Hi everyone,
I’m working on creating an SSRS report for printing labels using a BradyPrinter i7100, and I’m running into issues with getting the correct layout and sizing.
Requirement:
I need to print labels with the following dimensions:
Label Size: 0.25" (Height) × 0.9" (Width)
Horizontal Repeat: 1.125"
Vertical Repeat: 0.35"
Issue:
When I configure the report and print using SSRS Client Print, the paper size values appear incorrect (e.g., Paper Height = 25, Width = 35), and the output is not aligning properly with the actual label.
It seems like SSRS is using hundredths of an inch, but even after adjusting:
The label either prints too small
Or does not align correctly with the label spacing on the roll
What I’ve Tried:
Setting Report Page Size to 0.9in × 0.25in
Setting all margins to 0
Testing different page sizes including 1.125in × 0.35in to match label pitch
Checking printer driver settings for custom label size
Printer Dinensions:
Report Builder:
Report Printed from print preview:
Report output on label roll:
Getting Spacing, want to remove spacing.
Questions:
What is the best practice for handling label spacing (repeat distance) in SSRS?
Should the report page size match the label size or the repeat size?
Has anyone successfully configured SSRS with Brady printers (i7100 or similar)?
Are there any specific printer driver or SSRS settings required to avoid scaling issues?
Any guidance, sample RDLs, or suggestions would be really helpful.
Thanks in advance!
