We have been having problems with our PO SSRS Reports (we have three custom flavors). All work fine in PROD, but TEST is a mess. Only one works in TEST. I have copied down the style and RDD from PROD (for one that doesn’t work in TEST) and uploaded to TEST, but it fails. I think it has to do with the PrintProgram.
When I look in the SSRS “directory” (I know it’s not actually a directory) using the Server URL, there are seven folders under CustomReports. In Epicor, I have only five report styles. Only one (the report that works) has a PrintProgram that matches a folder in the server “directory.”
So… I am thinking that it be easiest to delete all the report styles from TEST and move (via Solution workbench or just download/upload) the three that work in PROD.
Questions:
If I delete a style from within Epicor, will the corresponding folder on the server also be deleted? What if there is no corresponding folder?
Is there any harm in deleting from the server all the PO folders and all the styles from the database and then bringing over the three working PROD reports in a Solution? If I do it this way, will Epicor create the correct print program for each?
I should note that the print program on the PROD reports (which do work) do not match to any of “folders” on the PROD server URL. Or is there not supposed to be a link between the “directory” folder and the print program?
Thanks.
