Mr. Joe: Thanks for the suggestion - that might work - I'll give it a try.
DaveO
DaveO
I am trying to recreate the Sales Order Ack line total for the overall order.
First - I know there is a field already that calculates the extended line amounts and sums up the lines. However - I would like to know how to do this manually. Let's say I want to control the number of decimals or manually add a discount or commission or tax.
So - I added a textbox to the Group1 (OrderNum) footer, and set the expression to "=Sum(Fields!DocUnitPrice.Value * Fields!SellingQuantitiy.Value,"Group1").
Group1 = OrderNum
Group2 = OrderLine
When I try to set the grouping value to "Group2" I get an error when I try to save.
The problem I am having is that the dataset has Sales Order Release Lines. All my Sales Order Lines have two (2) release dates. So the Sum function is double what it should be.
I have been pulling my hair out to try and solve this one. It can't be this complicated can it? I am just trying to get a "line" total summed up by Sales Order.
If anyone can offer a suggestion I would greatly appreciate it.
Thank you,
DaveO
Ph: 651-246-3281
I came up with the following solution:
Create a new Calculated field MyLineExtTotal and add a formula IIF(Fields!OrderRelNum.Value=1, Fields!DocUnitPrice.Value * Fields!SellingQuantity.Value,0)
That formula will set the new field equal to the line total ONLY for Order Release Line 1 otherwise it will set the field to Zero.
Then I was able to use a standard SUM() function to get the correct total.
I feel like this is a bit of a band aide way of doing it and presumes that there will always be a release 1. That may not always be true.
If someone out there has a more bullet proof solution - Please share.
DaveO
On Sun, Aug 9, 2015 at 3:58 PM, daveolender@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p></p><p>I came up with the following solution:</p><p><br></p><p>Create a new Calculated field MyLineExtTotal and add a formula IIF(Fields!OrderRelNum.Value=1, Fields!DocUnitPrice.Value * Fields!SellingQuantity.Value,0)</p><p><br></p><p>That formula will set the new field equal to the line total ONLY for Order Release Line 1 otherwise it will set the field to Zero.</p><p><br></p><p>Then I was able to use a standard SUM() function to get the correct total.</p><p><br></p><p>I feel like this is a bit of a band aide way of doing it and presumes that there will always be a release 1. That may not always be true.</p><p><br></p><p>If someone out there has a more bullet proof solution - Please share.</p><p><br></p><p>Thanks,</p><p><br></p><p>DaveO<br></p><p></p> </div><span class="ygrps-yiv-711422689"> <div style="color:#fff;min-height:0;"></div>
