Samcox
(Sam Cox)
December 9, 2024, 4:19pm
1
HI AlI have set up a BAQ report to show shipments and the country its gone to.
im now creating the report itself, i want it to just show somthing like this
Customer - Country - Amount of shipment (For example)
Matt - United Kingdom - 5
Matt - Spain - 2
at the moment its listening every shipment so all 5 records show, how do i go about not showing them all
see the picture below i’d want it to just say AMO609 - United Kingdom - 11
TDray
(Todd Dray)
December 9, 2024, 4:27pm
2
Without knowing exactly how you have it set up, it’s a little more difficult.
I made a quick one with ShipHead connectod to ShipTo.
I counted number of Packs sent to each country.
Calculated field set up like this:
I did have to set the results up as distinct, but then you get:
Hopefully that gives you enough to point you in the right direction.
kananga
(John K)
December 9, 2024, 4:39pm
3
I’d give it a shot with SSRS tablix grouping. There are a few options and you can get pretty fancy but a little poking around will get you where you’re headed.
Banderson
(Brandon Anderson)
December 9, 2024, 5:05pm
4
Instead of doing the windowing function, just group by the country (check the box on the field selection). Then you don’t need to use the “Distinct”.
count (shiphead.PackNum)
