Standard dashboards opening with incorrect layouts
I have noticed that when the layouts are not correct, if we log out and log back in, the form seems to be opening correctly without making any changes to the context menu. Do you know what is happening here or what would cause it to be pointing to an unspecificed context menu but then work as expected when logging back in?
--- In vantage@yahoogroups.com, "b_ordway" <cooner_55421@...> wrote:
> The only time I've seen this is when I use a customization and I haven't specified it context menu maintenance.
> --- In vantage@yahoogroups.com, "cchang015" <cchang015@> wrote:
> > Has anyone experienced opening up standard dashboards with the columns and layouts incorrect? For example, when we do a right click in the Job Number field in Job Entry and open the Job Status dashboard, the columns and form layouts are messed up. Has anyone seen this happening on standard and custom dashboards?
