Standard operation instruction sheet
thanks i will check it out
--- In vantage@yahoogroups.com, Carey S <rotary1@...> wrote:
> Are you referring to what Vantage calls OPERATION TEXT?
> If so, I believe it is core.
> You have a large free-text window with the ability to include
"any"thing you want and then select a checkbox to have it print on the
traveler.
> To: vantage@...: james.hill@...: Thu, 10 May 2007 11:38:35
+0000Subject: [Vantage] Standard operation instruction sheet
> Which module will allow us to make standard operation
instructionsheets in vantage? It's a detailed form of a tracker,
tracking eachevent to a single page.Thanks,James
> _________________________________________________________________
> Download Messenger. Start an i'm conversation. Support a cause. Join
now.
> http://im.live.com/messenger/im/home/?source=TAGWL_MAY07
Which module will allow us to make standard operation instruction
sheets in vantage? It's a detailed form of a tracker, tracking each
James
You have a large free-text window with the ability to include "any"thing you want and then select a checkbox to have it print on the traveler.
To: vantage@yahoogroups.comFrom: james.hill@...: Thu, 10 May 2007 11:38:35 +0000Subject: [Vantage] Standard operation instruction sheet
Which module will allow us to make standard operation instructionsheets in vantage? It's a detailed form of a tracker, tracking eachevent to a single page.Thanks,James
Download Messenger. Start an i�m conversation. Support a cause. Join now.
