Quick answer, yes. There may be a more forward path but I always had to change “Shells.”
Log into the “Classic Shell” and create a group called AutoLoad. (Favorites Tab, right mouse click, and choose “Add New Group” then rename it to AutoLoad.)
Next, right-mouse click the group add select “AutoLoad this Group”
Funnily I was looking into this earlier. The other way is to craft a sysconfig file based on the Alert Attachment. Then have a shortcut on your desktop based on your standard Epicor shortcut, but using the new sysconfig file.
Application Help search on Alert Attachment in the Application help. Create a simple attachment then click on the template tab and it will generate a sysconfig file that you can modify.
Here’s an example of the Shortcut section of to run the Labor Edit Report
You need to create a new menu and stick it in the Processes section. Although I did see the original menu id when I created the attachment. It may not be necessary to do this unless you had a specific customization you needed to apply.
