STK-STK Transactions
Hi Roger,
Inventory transfer should create GL transaction if the warehouse division point to two different GL divisions. Check the GL Control code for actual division assigment. It works for me. The reason for not appearing in Inventory COS and WIP could be both source and target account are resulting in same account.Â
Â
Regards,
Arul
Sent: Tuesday, 23 July 2013 11:25 PM
Subject: [Vantage] STK-STK Transactions
Â
This is a question for the accountants. I am trying to get the system to create a GL transaction based on movement from one warehouse to another. This is 9.05.702 and standard posting rules. The division is a code modifier, so setting up two warehouses "pointing" to two different GL (division) controls (say ' 01 ' and ' 02 ')should achieve this.
After the set-up, a part (with a cost) was transferred between the warehouses, but no record of the movement was shown in the Inventory COS and WIP reconciliation report.
Any thoughts gratefully received
You will not see the transaction in Inventory COS and WIP because the transfer does not cause a financial transaction. If you go to Part Transaction history, it will show the transaction.
Deirdre Sykes | Senior Cost Accountant
GSI Technologies, LLC | 311 Shore Drive | Burr Ridge, IL 60527
dsykes@...<mailto:dsykes@...> | Phone: 630.590.8112 | Fax: 630.325.8197
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of roger.clark88
Sent: Tuesday, July 23, 2013 8:26 AM
CONFIDENTIALITY: The information contained in this email message, including any attachment(s), may be privileged and confidential and protected from disclosure. The email is not intended for transmission to, or receipt by, any unauthorized persons. If the reader of this message is not the intended recipient, or an employee or agent responsible for delivering this message to the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication or use of the information contained herein is strictly prohibited. If you have received this electronic mail transmission in error, please delete it from your system without copying or disseminating, and notify the sender by Reply email, so that our address record can be corrected.
