Good Day Sanjay:
Create a second version of the Stock-Status and 'simplify" to
one line per part#.
You can just run the normal report, but then you will have to
clean up the Excell sheet after opening.
Run report and archive it so it goes to the system Monitor >>
"Print" the report using "Microsoft XPS Document printer" ( will not
print ), it will ask you to save as a file >> open the file with
Excel.
Sun is on E9 Version: 9.05.700C - SQL- Unidata - Enterprise-since
4/15/2012
Len
<<Picture (Device Independent Bitmap)>>
Of Jose Gomez
Sent: Tuesday, March 26, 2013 1:52 PM
To: Vantage
Subject: Re: [Vantage] Stock Status Quantity based on as of date
The easiest way to do this, is to run the report, then ParsetheXML into
a DataTable. Using something like VBA otherwise you can write your own
by looking at PartTran and adding / removing Parts one by one. I've done
this before and it works.
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.linkedin.com/in/josecgomez>
<http://www.facebook.com/josegomez>
<http://www.google.com/profiles/jose.gomez>
<http://www.twitter.com/joc85>
<http://www.usdoingstuff.com>
On Tue, Mar 26, 2013 at 1:39 PM, sanjay219@...
<sanjay219@...>wrote:
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
one line per part#.
Excel.
4/15/2012
Len
Of Jose Gomez
To: Vantage
*Jose C Gomez*
*Software Engineer*
E: jose@...
> **working.
> I need to import the stock status report to an excel spreadsheet. I am
> using Vantage 8.03.409c. I used tables PartTran and Part. I tried
> backing off the transactions from current OnHand Quantity. But its not
> Please help me figure it out, what i am missing.[Non-text portions of this message have been removed]
> Thanks,
> Sanjay.
