Stock Status Report - filter by Part #
If it is a one off, create a part Class that is called "Temp"
Select your 30 parts, change the part class (keep a list so you can fix it later)
Run the report and put the class back to what is was.
Bruce
--- In vantage@yahoogroups.com, "michael.hutcheson@..." <michael.hutcheson@...> wrote:
> it is just a one off for the auditors who want it pretty quick.
> --- In vantage@yahoogroups.com, "CharlieSmith" <CSmith@> wrote:
> > Are they always the same 30 parts? Are they different classes?
> > You are better off writing a BAQ and BAQ Report.
> > Charlie Smith
> > 2W Technologies LLC, Sr. Business Consultant
> > Phone: (312) 533-4033 x8046
> > (860) 620-9553
> > Fax: (847) 374-3620
> > 2W Tech on Facebook
> > <http://www.facebook.com/pages/Chicago-IL/2W-Technologies-LLC/1391945694
> > 32409> www.2WTech.com <http://www.2wtech.com/>
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf
> > Of michael.hutcheson@
> > Sent: Monday, December 06, 2010 11:59 AM
> > Subject: [Vantage] Re: Stock Status Report - filter by Part #
> > we are after info in the stock status report for approx 30 parts...
> > --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> > "Dale Schuerman" <dale.schuerman@> wrote:
> > > If you are looking at only one part number wouldn't "Part Tracker" or
> > > "Part On-Hand Status Dashboard" work?
> > > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> > Behalf
> > > Sent: Monday, December 06, 2010 10:25 AM
> > > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > > come to think of it, could i just create a BAQ search using the part #
> > > --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <
> > > "michael.hutcheson@" <michael.hutcheson@> wrote:
> > > > Hello,
> > > > I've had a request to configure the stock status report to filter by
> > > part #. Is it possible to add filters to standard Vantage report
> > > options? Currently you can only filter by Part Class and\or plant. My
> > > other thought was to create a copy of the stock status report and then
> > > have this prompt the user for a part number - however, every single
> > Part
> > > Number would have to be dumped out first which takes some time.....
> > > > Any ideas?
> > > > Thanks,
> > > > Michael
> > > > Vantage 8.03.406/Progress
> > > Attention:
> > > This email message is privileged and confidential. If you are not the
> > > intended recipient please delete the message and notify the sender.
> > > Any views or opinions presented are solely those of the author.
> > > This email message has been scanned for Viruses and Content and
> > cleared
> > > by MailMarshal SMTP
> > > For more information go to http://www.ramsys.com
Hello,
I've had a request to configure the stock status report to filter by part #. Is it possible to add filters to standard Vantage report options? Currently you can only filter by Part Class and\or plant. My other thought was to create a copy of the stock status report and then have this prompt the user for a part number - however, every single Part Number would have to be dumped out first which takes some time.....
Any ideas?
Michael
come to think of it, could i just create a BAQ search using the part # ?
> Hello,
> Any ideas?
> Thanks,
> Michael
no, that doesn't work
> --- In vantage@yahoogroups.com, "michael.hutcheson@" <michael.hutcheson@> wrote:
> > Hello,
> > Any ideas?
> > Thanks,
> > Michael
Of michael.hutcheson@...
> Hello,
> Any ideas?
> Thanks,
> Michael
Attention:
This email message has been scanned for Viruses and Content and cleared
by MailMarshal SMTP
> > Hello,
> > Any ideas?
> > Thanks,
> > Michael
> Attention:
> by MailMarshal SMTP
You should be able to load those 30 parts into a UD table(or hard code
the 30 parts into the BAQ filter).
Write a BAQ to read the UD01 and link to the PartBin(other tables if
required).
Write a dashboard or a BAQR using the BAQ
Sent: Monday, December 06, 2010 10:59 AM
Behalf
> > Hello,
Part
> > Any ideas?
> > Thanks,
> > Michael
> Attention:
cleared
> by MailMarshal SMTP
Charlie Smith
(860) 620-9553
Fax: (847) 374-3620
2W Tech on Facebook
Behalf
> > Hello,
Part
> > Any ideas?
> > Thanks,
> > Michael
> Attention:
cleared
> by MailMarshal SMTP
The big feature of the regular stock status report is the "as of" date. If you just want the current snapshot, BAQ advanced search dashboard will work fine.
And I would use analysis code or one of the UD checkbox fields in part maintenance to flag the part rather than take up a UD table.
> Hello,
> Any ideas?
> Thanks,
> Michael
> Charlie Smith
> (860) 620-9553
> Fax: (847) 374-3620
> 2W Tech on Facebook
> Behalf
> > > Hello,
> Part
> > > Any ideas?
> > > Thanks,
> > > Michael
> > Attention:
> cleared
> > by MailMarshal SMTP
