Hi,
We have a warehouse with 2 lot numbers which have different quantities, yet when we run the stock status report, it reflects a negative amount.
Below are screenshots attached.
Please assist.
Hi,
Please assist.
@varanimesh If you look in part tracker are there other warehouses or bins that offset this negative balance. We found that if we used just FIFO with Lot tracking and not LotFIFO you could get your bins and lots out of sync with FIFO layers.
@gpayne we use standard costing method. Yes there are other warehouses which have stock items to offset this negative balance.
