Stop a BAQ Report with empty paramaters
Is there a way to stop a BAQ Report from being submitted none of the parameters are filled out?
TIA
Greg
I would enable tracing and see what method is being called on the BAQ report and created a BPM. On the submit of the report you could have a stop to show an error when the parameters are empty.
You can create an embedded customization to ensure the user enters parameters.
I am going to try again with a bpm and if that doesn’t work i will work on doing the customization.
Greg
