Dell Keyboard swapped out for generic and it is now working.
Thanks I was really racking my brain thinking it was a .net update
issue.
issue.
--- In vantage@yahoogroups.com, "Dale Dalton" <daled@...> wrote:
> Sounds similar to an issue I had with a specific type of mouse. Some of my
> users have 4 button Dell wheel mice. I finally figured out that the Dell
> driver for that particular mouse doesn't play nice with Vantage.
> Dale Dalton
> _____
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> mmcwilliams22
> Sent: Wednesday, July 20, 2011 3:35 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Strange client UI issue one user
> We are on 8.03.408 and have an issue that just started happening for a
> single PC.
> Normally when hitting tab to enter a field of any type if the field is
> populated all of the text will be highlighted.
> However with this user now only when entering a decimal field does it
> highlight all of the items. If you are tabing through where a field is
> defaulted to 0 like an invoice, so or any other field the cursor is in front
> of the zero.
> They are typing or scanning through and then start to get errors because
> records are not found(trailing 0 left behind) Has anyone seen this issue? I
> can't figure it out. I have tried to modify the default config to select
> text on enter but that does not fix it.
