Miguel, thanks so much. That worked!
Best regards
Mike Abell
IT Manager
Flexial Corporation
a company of BOA Group
1483 Gould Drive, Cookeville, TN 38506, USA
Phone: +1 931 432 8408
Fax: +1 931 432 1889
Mail: mabell@...
Website:
http://www.flexial.com
http://www.boagroup.com
Sent: Thursday, May 12, 2016 1:03 PM
Subject: RE: [Vantage] RE: Strange error - can't enter a labor qty on a job assembly - Epicor 9.05.702A
1. Unrelease Job
2. Note Prod Std.
3. Change Operation to anything ( Change the operation in question)
4. Save
5. Change back operation to original
6. Enter Prod Std.
7. Save
8. Release.
Miguel A. Santillan
Compass Manufacturing Systems
Sent: Thursday, May 12, 2016 10:55 AM
Thanks Greg, that helps a lot!!
Sent: Thursday, May 12, 2016 11:54 AM
Subject: [Vantage] RE: Strange error - can't enter a labor qty on a job assembly - Epicor 9.05.702A
We had this error and Epicor had me change the time on the production calendar we were using. We don’t schedule to the hour, so I had clicked hours 1-7 for 7 hours of capacity per shift. Epicor had me change to 6-12 for the seven hours and the message went away.
When I looked at the job/sequence in question in the ResourceTimeUsed table the time was either zero or went backwards for that operation.
The original suggestion from Epicor was to unscheduled/reschedule the job which does work to align the time again, but several a day of that gets old quickly.
Greg
Sent: Thursday, May 12, 2016 12:22 PM
Subject: [Vantage] Strange error - can't enter a labor qty on a job assembly - Epicor 9.05.702A
We had an error come up that says “Internal error. Scheduling dates in RESOURSETIMEUSED file are not consistent for Job 30702-a3 Assembly 5 Sequence 30. It would not let us enter a production labor qty, this message keeps popping up. Any ideas what causes this?????
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail:
mabell@...
Website: http://www.flexial.com
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible
for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6240 and immediately
delete the communication.
"This (document/presentation) may contain technical data as defined in the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10. Export of this material is restricted by the Arms Export Control Act (22 U.S.C. 2751 et seq.) and may not be exported
to foreign persons without prior approval form the U.S. Department of State."
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
