The same issue started happening to us around the same time. I think it may tie in with some Windows updates, but I'm not sure. I haven't been able to figure out the issue yet.
--- In vantage@yahoogroups.com, "adam.whipp" <adam.whipp@...> wrote:
> We are running XI R2 SP5 everywhere. However, if SP6.4 exists, I will go search for that.
> Thanks,
> Adam
> --- In vantage@yahoogroups.com, "cubcrafters_it" <jason.navarrete@> wrote:
> > Do you have different versions of the runtimes installed on the local instances vs the RDP instance? We were running XI R2 SP6.4 when we were on Vista 8.03.
> > --- In vantage@yahoogroups.com, "adam.whipp" <adam.whipp@> wrote:
> > > Starting a couple weeks ago (possibly related to windows updates) we started having some weird printing problems from the crystal reports runtime.
> > > On PC's where Vanatge is installed locally, we experience different behavior when print previewing vs printing without previewing. A good example is the job traveler: we have a landscape legal sized job traveler. If I print preview it first, it will print fine. If I try to directly print it without previewing it, it will print on letter paper (even if I override the settings to change it to legal). This only starting happening about 2 weeks ago, and it is widespread.
> > > On users who connect to our 2008 R2 terminal server, we keep running into an error message that states: "Print driver host for 32 bit applications has stopped working". If we close the RDP, and reboot the local PC, then reconnect the RDP, it will work.
> > > Both problems started happening at the same time (about 2 weeks ago). Has anyboy else seen any crazy behavior like this?
> > > Thanks,
> > > Adam Whipp
> > > National Tube Form
