Strange Thing Selecting a Job
Speaking of strange things why when you first load vantage does it say "TREE
TOP" above the menu list. I guess I will have to rewrite all of my work
instructions to first say, "Go under the Tree Top", "Then select Job
Management", etc...
Patrick J. Winter
Information Services Manager
sSc Specialty Screw Corporation
Vantage 4.00.901
Sent: Wednesday, January 03, 2001 08:59 AM
To: 'vantage@egroups.com'
Subject: RE: [Vantage] Strange Thing Selecting a Job
This actually not a "bug". Progress/Vantage allows you to enter filters
into the selection criteria boxes. However, because of the way
Progress/Vantage handles this quasi query against the database it takes a
very long time. What you are seeing is Progress filling in the lookup table
for the screen adding one record at a time to the list.
This "function" has been around since at least version 2.0. You can use it
to enter lookup masks like ME* to bring up everything that begins with an
ME. However, because it takes so long, it isn't very useful.
The only way to stop it I have found is to kill it like you did.
Rick Lane
Intelligent Systems Integration, Inc.
661 B Weber Drive
Wadsworth, OH 44281
Phone: 330-335-5291
"Helping Business Make Intelligent Use of Technology"
A user here was selecting a job for a job traveler and her finger slipped
off of the numeric keypad Enter key and hit the period/decimal point key.
Not seeing this she pressed enter and selection portion of the screen went
totally crazy and started scrolling through all the jobs in the system. over
and over and........endless loop.. The only way to stop it was to
Ctrl-Alt-Del and end task on Progress. We tried it again and it is
repeatable. Looks like a bug to me but before I check with Tech Support I
wanted to see if this was really an some sort of feature I have not learned
yet. Has anyone else seen this or know any significance to entering a
period in a selection field? Is there a kinder and gentler way to stop it
than ending the task?
-Todd Caughey
Harvey Vogel Mfg. Co.
-Todd Caughey
Todd -
Kewl !
hehehehehehe
There are some instances when professionalism
has to be put back on the shelf.
Calvin
BTW: It's a bug.
----- Original Message -----
To: <vantage@egroups.com>
Sent: Wednesday, January 03, 2001 8:49 AM
Subject: [Vantage] Strange Thing Selecting a Job
over
learned
> Thanks,
> -Todd Caughey
to www.egroups.com, login and be sure to save your password, choose My
Groups, choose Vantage, then choose Files. If you save the password, the
link above will work the next time you try it.)
Works for me. Ending the task was the only way to get it stop.
Terry L. Williams I.S. Manager Chipsco, Inc. 993 Liberty St. Ext.
Meadville, PA 16335 814-333-6331 x236 fax: 814-337-2548 tlw@...
www.chipsco.com
Sent: Wednesday, January 03, 2001 9:49 AM
-Todd Caughey
Wow, that's neat. Mine does it too (3.00.632) I checked, and it only
affects the client machine. There appears to be no excessive load on the
server. Probably a logic bug in their browse thingy...
-Wayne Cox
Rick Lane
661 B Weber Drive
Wadsworth, OH 44281
Phone: 330-335-5291
-Todd Caughey
