Stuck - Pivot Aggregate Formula
Can you do a case statement in the pivots’ aggregate? I can’t seem to get it to work, lol.
The issue is that when a count is returned null in the pivot nothing is returned but I want the remaining data returned. This only happens in the pivot. Any advice to get the data I need is appreciated.
sum( case when Calculated_PurchaseCount = null then 0 else Calculated_PurchaseCount end )
Could you try
case when Calculated_PurchaseCount != null then Calculated_PurchaseCount
else 0
end
That’s not working either. I tried to eliminate the null is the sub query as well and that’s not working.
Change you calculated field in outermost value, if it is complex…eg:
I tried this and are getting the same results. :worried:
Jessica,
Purchase_Count sounds like an aggregate calc value in another subquery, I think you need to eliminate the nulls the first time the field is referenced.
If the first reference is an aggregate then you can do something like this:
ISNULL(Count(YOURCNTFIELD), 0)
If that doesn’t work, can you post your query, context is everything.
See attachment.
You need to put your IsNull in each of your Calculated field months,like this:
Your Pivot Aggregate does not need the IsNull function.
(I made a mistake on my earlier post the IsNull is best inside the Aggregate function to avoid other issues)
-Rick
www.getaligned.soutions
Here is the corrected file:
RLB-InventoryAnalysis.baq (29.6 KB)
Thanks Rick. I’m still only getting 7062 returns. I should get over 39K. I was able to replace NULLS with zeros before but for all parts that have NULLS across the Months aren’t returning.
Jessica,
FYI - I am traveling today, but until later: I suspect that you are expecting records and data for things that don’t have any records? I would have to look at that BAQ again but you might have an inner join where you might want a left join so that ALL parts are returned instead of just parts with matching records in the other table.
I have all left joins up to the part numbers so I would have assumed it would have returned part numbers with no data. Hope to talk later when your free. I am going to move on to another BAQ for now :slight_smile:
I figured out what wrong. Thanks everyone for the response.
I had to add the part table to the Top level query and do a left join to the sub-query to get all the part number to return. Silly me :slight_smile:
Glad you figured it out!
I was just going to ask about the criteria on the Part table, thinking that was limiting your results.
Nice job!
