Sub-Assemblies and Product Configurators
When we set our quantities, it does have to be a decimal field in configurator or hard coded in on the rules in the BOM in order to set the feild. It looks like you are using the correct setting. Our rule is as follows: Set Field JobAsmbl.QtyPer = Qty (Qty is our decimal field in PC)
--- In vantage@yahoogroups.com, Norman Hutchins <nhutchins@...> wrote:
> I tried used just a number as a test (Set Field JobAsmbl.QtyPer = 2.00000),
> but that didn't work either. So I'm starting to think that I'm using the
> wrong set field, it's like that PC doesn't know which Asm to set the Qty
> for, i.e. Asm 0 for the main or Asm 1 for the 1st subasm.
> Any other ideas?
> Norman Hutchins
> Network Administrator
> Howell Laboratories, Inc.
> Shively Labs
> 207-647-3327
> ____________________________________________________________________
> This email was sent by Howell Laboratories, Inc. or Shively Labs. It may
> contain information that is confidential or privileged. If you suspect you
> were not intended to receive it, please delete it without copying or
> forwarding it, and notify the sender by reply email or by
> calling 207-647-3327.
Hello,
Sub-Assemblies are driving me crazy in the configurator. We had a PC for a
part that was working correctly and then production wants to change a bunch
of mtls to sub-assemblies, which sounds easy enough.
We created a new Rev. and changed the mtl to pull as assemble, then I
changed the set field rules from JobMtl.QtyPer rules to JobAsmbl.QtyPer
rule. This is the rule:
Set Field JobAsmbl.QtyPer = (Decimal(P01_cmb_NumbBay))
But when I run the PC and create a job from it, it�s only calling for a Qty
of 1 of these parts not matter what P01_cmb_NumbBay equals.
Any thought or ideas?
Norman Hutchins
Shively Labs
207-647-3327
Try it from a decimal field (updating from the cmb value)
> Hello,
> But when I run the PC and create a job from it, it's only calling for a Qty
> Norman Hutchins
> Shively Labs
> 207-647-3327
but that didn�t work either. So I�m starting to think that I�m using the
wrong set field, it�s like that PC doesn�t know which Asm to set the Qty
Any other ideas?
Norman Hutchins
Shively Labs
207-647-3327
