When your BOM creates demand for manufactured parts, the parts can be demanded from another job (as sub-assemblies) or from inventory (as materials). Only material demands on inventory can be seen on the Time Phased Material Requirements Report.
If you want to see demand for subassemblies in the Time Phase, you'll have to set them up in the part master as stock manufactured items, and give them max, min and safety quantities, and a part class. AND you have to restructure your BOM or Job Details so that the sub assemblies parts are pulled as material parts. When you run the Time Phased Material Requirements Report, use the Manufactured and Stock filters and select the part class....
----- Original Message -----
To: Vantage@egroups.com
Sent: Wednesday, October 11, 2000 2:51 PM
Subject: [Vantage] Sub-Assembly in the time Phase
A Question for all the production manager. If you have a job for a part
on a job with 3 or 4 Sub-Assy parts under that main part you are making
How do you see that your making that Sub-assy part on the shop floor in
the time pahse ? I must be
missing something here, Right.. Any Ideas would be helpful. How is the
rest of the
vantage world working this ?
Ex. Part-A < Main Part
.Part-b < Sub-assembly "b" How can I see that I am making
these ?
.Part-c < Sub-assembly "c"
.Part-d < Sub-assembly "d"
Jeff
eGroups Sponsor
We no longer allow attachments to files. To access/share Report Files, please go to the following link: http://www.egroups.com/files/vantage/
(Note: If this link does not work for you the first time you try it, go to www.egroups.com, login and be sure to save your password, choose My Groups, choose Vantage, then choose Files. If you save the password, the link above will work the next time you try it.)
