Subcontract PO with PUR-UNK
An odd-ball scenario here…
Let’s say I’m sending parts out to a subcontractor for an operation… I’ll use sand-blasting as an easy example.
The Subcontract PO can accept parts from multiple jobs, great. So we’re sending them (3) parts to get blasted based on job subcontract ops.
We also want to send them a part from one of our own production machines to get blasted/cleaned along with the parts tied to subcontract operations.
The PO allows for this. You can add a line for “Other” which is then a PUR-UNK transaction. So, our PO now has (3) subcontract lines, and (1) “Other” line.
The problem is, Subcontractor Shipment Entry won’t allow you to SHIP a part unless there is a related job number. So, event though the PO includes a Line for “other”… I can’t ship it.
Can anybody think of a clever way around this?
I can do a misc. shipment, which makes sense since I’m not receiving this “other” part back to a job or inventory. But, I’m hoping I don’t need (2) packing slips for (1) shipment. I could put all the parts on the misc. shipment, but then the subcontract flow breaks down. No “clear” record of the subcontract parts being sent out, not received to the job when they come back, etc.
I could create a random stock job with a placeholder part and a subcontract operation and potentially re-use that over-and-over again when scenarios like this pop up. The problem is we would have to close that job at certain intervals so the costs get passed through the system. But the costs would need adjusted anyway to get to the right GLs. In these cases the costs shouldn’t go to COGS GLs, but to operational/maintenance GLs instead. That’s the beauty of using a PUR-UKN PO line, we can steer the costs to the desired GL.
Any thoughts/insights?
I think the best option here is to suck it up and do the two slips. You can easily explain it off to the subcontractor as it being because of accounting. To me, anything is actually creating more work than just doing two slips.
Do you have the Maintenance module? If so, you can do the outside processing on the Maintenance Job and have the accounting all correct AND keep track of the costs of ownership for that equipment. Just a thought.
nope.
Season 9 Smh GIF by The Office
As @jkane mentioned, two pack slips is the most straight forward… its just listening to the operations guys whine about having to do do it that I’m trying to avoid. But… if that’s what we gotta do, that’s what we gotta do.
The PO side works fine. Its just the pack slip.
Hug GIF by The BarkPost
I appreciate the comforting support.
I’m just assuming the below response from my guys…
“You mean I have to do TWO packing slips?!!?”
Oh No Omg GIF
Can’t please everybody.
Maybe the Juice isn’t worth the squeeze, but you could programmatically create the pack slip for them, just need to figure out the trigger. :thinking: probably after a po is approved check for an other line, then have a function which creates the misc slip.
I don’t like them THAT much! :rofl:
Create a job with one operation for sandblasting
Create a part on the fly called Sandblasting
On your three jobs put sandblasting on as a material
For your maintenance part, create a job with sandblasting as material
With a fixed qty.
Assign a product group with MfgVariance to the expense Gl
Do not put in a demand link
Back on the sandblasting job set up job to job links
Hopefully this makes sense
How’s it know it has a related job number does it just look the po line…
Never tried this and I don’t think you should as I am sure it will cause receipting issues if you did…
What if you bogus up the job number etc when the ship process occurs…
Not sure it is worth the hassle to do this… but just another out loud thought
:slight_smile:
