Subject: RE: Crystal reports-selection criteria fields
seems like this had something to do w/converting from office 97 to 2000 and xp pro os. also this access database is on a network drive w/more than one path. I'm not sure. I had to copy and rename my access databases when I upgraded my systems. It is a little confusing, not sure if I can explain it all.
I ended up adding another table to my report, which is the same table only w/a different path and renamed it slightly and was able to use the fields in selection criterea, works now! not sure now if i got the right path to the database originally or what?
thanks for your response.
dennis
----- Original Message -----
Sent: Friday, July 11, 2003 1:49 PM
Subject: RE: [Vantage] Subject: RE: Crystal reports-selection criteria fields
Babette wrote "The other thing I have used is make a formula field which is
equal to a substring of the blob field."
The above statement is the approach I take for long blob fields like
PartDescription.
Troy Funte
Liberty Electronics
Sent: Friday, July 11, 2003 2:47 PM
Subject: [Vantage] Subject: RE: Crystal reports-selection criteria fields
There is an instruction from the 'AnswerBook' which explains how to
decrease the size of a field.
This is for blob/memo fields.
It is not for the faint-of-heart.
You are changing the length of the field in the database.
It then allows for Crystal to use the field in criteria.
The other thing I have used is make a formula field which is equal to a
BW
Sent: Friday, July 11, 2003 11:45 AM
To: vantage
Subject: [Vantage] Crystal reports-selection criterea fields
Hello group,
I am having some problems on getting fields needed for selection criterea
to show up as a choice for filtering or formulas, they show in the field
list, but not as a choice for selection or formulas. This is w/odbc and
access office 2000.
thanks
dennis
Babette Welch
MIS Director
Argonics
1110 Wright
Marquette MI 49855
906.226.9747 ext 235
906.228.0951 fax
Yahoo! Groups Sponsor
ADVERTISEMENT
ADVERTISEMENT
There is an instruction from the 'AnswerBook' which explains how to decrease the size of a field.
The other thing I have used is make a formula field which is equal to a substring of the blob field.
BW
To: vantage
Hello group,
access office 2000.
thanks
dennis
Babette Welch
MIS Director
Argonics
1110 Wright
Marquette MI 49855
906.228.0951 fax
PartDescription.
Troy Funte
Liberty Electronics
BW
To: vantage
Hello group,
access office 2000.
thanks
dennis
Babette Welch
MIS Director
Argonics
1110 Wright
Marquette MI 49855
906.228.0951 fax
ADVERTISEMENT
