When a make direct part is entered in Sales Order it also shows up in
the planning work bench in Job entry. From there you can create the job,
get details etc.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of Chris Stover
Sent: Wednesday, June 22, 2005 3:25 PM
Subject: RE: [Vantage] Make Direct Parts
Even without the MRP module you should have that opportunity to select
any
specific part to make into a job. When you go into Job Entry up on the
top
there is the Planning Workbench option. You simply select that option
and
it will give you the list of parts that have sales orders and are marked
Make Direct. You simply highlight which part you want and select Create
a
Job.
Do all of your parts in your system have BOM's attached to them? If so
you
can simply check mark the Get Details option after you hit next job
number
and the BOM's will come with the creation of the Job for that Part. But
if
not, you will have to create the BOM with the part.
Chris Stover
Business Control Engineer
Deaver Industries
205-426-4309 Voice
205-426-4364 Fax
cstover@...
www.deaverind.com
Of
Rough Brothers
Sent: Wednesday, June 22, 2005 2:13 PM
To: Vantage Users
Subject: [Vantage] Make Direct Parts
Someone has to have a better way of manufacturing (creating a job) Make
Direct Parts.
Creating a job to Manufacture a "Make Direct" Part is not easily done.
Suggestions for Make Direct Parts only show up in the Time Phased
Material
Report. Once you discover you need to create a job for this make direct
part ... everything is manual. Manually create the job, manually select
the
part, manually assign the job, manually select the operation, manually
select the part to be manufactured (you can actually select other items
that
are NOT make direct), manually select the date to complete (date to
complete
is not tied to the original job). It is extremely cumbersome.
All this could go away if Vantage had a "Make Direct Suggestions"
similar to
PO Suggestions.
We have also discovered that the "Demand" for Make Direct Parts is not
summarized (accumulated) in Part Tracker. It apparently nets the
"suggestion" that shows up on the Time phase report with the Demand from
the
job and creates a demand of "zero". Don't understand why demand does
not
show up?
Therefore, if we run a query ... Demand for Make Direct Items does not
show
up.
Does anyone have a better way?
I guess the above is why Epicor sells the MRP module ....
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
have
and
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
<http://docs.yahoo.com/info/terms/> Service.
have
and
Yahoo! Groups Links
________________________________________________________________________
Message: 3
Date: Wed, 22 Jun 2005 20:45:52 -0000
Subject: Re: Dashboard Query
Here is what I have. What I would like to NOT see are any lines where
there are 0 parts in the RAW warehouse. If there are 0 parts in any
other warehouse, I would like to see those.
Any help would be MUCH appreciated.
Thanks!
Ben
get details etc.
Of Chris Stover
any
top
and
a
Job.
you
number
if
Chris Stover
Deaver Industries
205-426-4309 Voice
205-426-4364 Fax
cstover@...
www.deaverind.com
Of
Rough Brothers
To: Vantage Users
Direct Parts.
Material
the
that
complete
similar to
PO Suggestions.
the
not
show up?
show
up.
Do You Yahoo!?
have
and
_____
Yahoo! Groups Links
have
and
Yahoo! Groups Links
Message: 3
Thanks!
Ben
--- In vantage@yahoogroups.com, "Aaron Hoyt" <aaron.hoyt@v...> wrote:
> Ben,
> You can add a filter in the query where the linking is done.
> For instance where you call the PartWhse table,
> Add a line that reads... PartWhse.OnHandQty > 0
> If you need more detail, post the contents of your query.
> Good luck,
> Aaron Hoyt
> Vantage Plastics
Behalf
> Of bbelzer42
> Sent: Wednesday, June 22, 2005 3:23 PM
> Subject: [Vantage] Dashboard Query
> I have a dashboard query that shows me everything I have on hand for a
> part. It shows the part twice (two lines) if it is in 2 warehouses.
> Is there a way to keep a line from showing? Ie: If the Warehouse has
> 0 on hand, can I make the line not show?
> Thanks,
> Ben
must have
Builder and
> Yahoo! Groups Links
Message: 4
Date: Wed, 22 Jun 2005 20:46:32 -0000
Oops... left the code out:
for each PartPlant Where PartPlant.Company = cur-comp no-lock,
each PartWhse Where PartWhse.Company = PartPlant.Company
and PartWhse.PartNum = PartPlant.PartNum
no-lock,
each Part Where Part.Company = PartWhse.Company
and Part.PartNum = PartWhse.PartNum
and Part.NonStock = no and
Part.TypeCode = 'M' no-lock
BY Part.PartNum:
Thanks! Ben
> Ben,
> Good luck,
> Aaron Hoyt
> Vantage Plastics
Behalf
> Of bbelzer42
> Thanks,
> Ben
must have
Builder and
> Yahoo! Groups Links
Message: 5
Date: Wed, 22 Jun 2005 13:57:07 -0700
Subject: RE: Multi-Site Management
You would still need to switch "plants" to see some information. I
haven't worked with multiple companies yet but multi-plant does require
a lot of changing back and forth between plants to access a lot of PO,
Inventory and Job information.
Sue
Sent: Wednesday, June 22, 2005 8:15 AM
Subject: [Vantage] Multi-Site Management
We have a separate company (same ownership) that supplies raw material
to us. Our demand generates a sales order to them and a PO for the
parent company.
The order must be shipped on the supplying company, and received on the
parent company. The demands of the parent company are not visible
to the supplying company, even tho each company is using vantage (set up
as separate companies). Users must switch to the other company
to view and maintain the other company records.
Question: does multi-site management lessen the need for all of the
care and feeding of the above scenario?
regards
_____
Yahoo! Groups Links
Service <http://docs.yahoo.com/info/terms/> .
Message: 6
Date: Wed, 22 Jun 2005 14:00:09 -0700
Subject: RE: Sales Order Demand (Purchase Direct)
You are correct as far as I know. That's how we do it - create the S/O,
create a Job, create the PO for the part, receive it and ship from the
Job.
Sue
Sent: Wednesday, June 22, 2005 5:54 AM
Subject: [Vantage] Sales Order Demand (Purchase Direct)
Thanks for the response.
I can see that a "Make Direct" item can be seen in Order Job Wizard (a
job would be created to make the item) ...
However, I am still unable to see "Purchase Direct" items in PO
suggestions from a Sales Order. (Scenario would be that we are going to
purchase this item specifically for this sales order.) .... not pull
material from inventory.
I am assuming that I am going to have to create a job from the sales
order and then have the Purchase Direct Material sitting in the job to
be able to view the demand in PO Suggestions.
ehahn@... wrote:
You will still get a demand for non-stocked items. It will be to
inventory,
not linked to the Sales Order. (I think the AMM lets you link direct to
the
Sales Order, but someone would have to confirm)
Liz
Sent: Tuesday, June 21, 2005 09:04 AM
To: Vantage Users
Subject: [Vantage] Sales Order Demand (Parts Orders)
Vantage 6.1
I want to make sure I understand this correctly.
Stocked Items ... For Parts that are "Stocked", you can enter the demand
in
the Sales Order and it shows up in Time Phased as demand for the Sales
Order
... "Go ahead and pull if from Stock"
Purchase Direct Items - If you enter an Item on the sales order that is
a
PURCHASED "Non-Stocked" Part in the system, demand does not show up
anywhere
.... ie, you can not create a PO to purchase the "Non-stock" item that
sits
on a Sales Order. You would first have to create a JOB tied to the
Sales
order and enter the Purchased "Non-Stock" item in the Job to create the
demand.
Please confirm my understanding.
Yahoo! Sports
Rekindle the Rivalries. Sign up for Fantasy Football
have
and
<http://groups.yahoo.com/group/vantage/files/.
<http://groups.yahoo.com/group/vantage/files/> >
_____
Yahoo! Groups Links
<http://groups.yahoo.com/group/vantage/>
Service
Yahoo! Groups Links
Do You Yahoo!?
_____
Yahoo! Groups Links
Message: 7
Date: Wed, 22 Jun 2005 17:01:24 -0400
Subject: RE: Re: Dashboard Query
Ben,
I am on my way out the door, so this is untested, but something like
below
should do the trick.
You may have to play with the syntax a bit.
and PartWhse.WarehouseCode = "Raw"
and PartWhse.OnHandQty > 0
or PartWhse.Company = PartPlant.Company
and PartWhse.WarehouseCode <> "RAW"
no-lock,
BY Part.PartNum:
Good luck,
Aaron Hoyt
Vantage Plastics
Of bbelzer42
Sent: Wednesday, June 22, 2005 4:47 PM
Subject: [Vantage] Re: Dashboard Query
no-lock,
BY Part.PartNum:
Thanks! Ben
> Ben,
> Good luck,
> Aaron Hoyt
> Vantage Plastics
Behalf
> Of bbelzer42
> Thanks,
> Ben
must have
Builder and
> Yahoo! Groups Links
have
and
Yahoo! Groups Links
Message: 8
Date: Wed, 22 Jun 2005 21:04:04 -0000
Subject: OT - Job Opportunity in Central PA
KRB Machinery has an opening for an Operations Manager with strong
Vantage implementation experience. If interested, please send resume
to nathan@...
Yahoo! Groups Links
