Subreport wont display in vantage
Thank you, thank you, thank you. And THANK YOU! :)
Dunn, Nancy
Sent: Friday, January 27, 2006 11:13 AM
Subject: RE: [Vantage] Subreport wont display in vantage
Rebecca,
This is the information I got from Support.
I'm sorry the patches are at the FTP site. You need to log in with your
Site ID and password.
If you have any problems, give support a call. It might be best to give them
a call anyway.
Nancy
The information on Crystal and the patches are as follows:
Crystal Reports 8.5
Technical Support Information
Crystal Reports version 8.5.2.718
The version of Crystal that comes on your CD, is version 8.5.0.217.
This version needs to be patched up to 8.5.2.718 which can be found on our
FTP site.
ftp://ftpmpls.epicor.com\MFG6\Crystal\crystal85_all_patches.zip
There are three patches in this file. All of them will need to be applied
to your CR 8.5 program, in the following order:
CR85mainwin0902_EN.zip
scr8_distr_expert.exe
Crystal Decisions Database and Export Patch.exe
The installation of Crystal Reports is always done on a workstation(s) that
will be doing the developing and designing of the reports. It is almost
never installed on the server. The installation is very straightforward,
you will install it to the default location which is C:\Program
Files\Crystal Reports.
Two very important documents on how to get connected to the database
are:
Page # 3436MPS - Which explains how to modify existing forms.
Page # 2771MPS - Which explains how to create an ODBC connection for
connecting to our Progress database to write reports from scratch.
Rebecca Schmuck
Sent: Friday, January 27, 2006 11:49 AM
Cc: dsenift@...; 'Dave Yurik'; 'Roger Behrens (E-mail)'
Nancy,
Where did you get the patches from Epicor? I am only on Crystal 8.5.0.217,
and that was after downloading the patch this morning that was on EpicWeb.
Rebecca
Yahoo! Groups Links
hello to all,
I am having problems with viewing a subreport in a main report(using
Crystal Reports 8.5) in Vantage 6.1, I am trying to figure out if the
link between the database and report is broken but when I checked it
seemed alright. I have viewed the report already but cant anymore. I
have browsed the data fields I've used and found the right contents to
display.
Can anyone suggest how I can fix or troubleshoot the problem
I don't know if this could be the same thing, but when we converted to
6.1, I had problems with some forms. The detail on the invoices and
checks on any page after page 1 didn't show.
Support had me reinstalled Crystal 8.5 then only installed the patches
from Epicor (MFG6\Crystal folder) that took Crystal to version
8.5.2.718. The details showed up then. (I was on a higher version)
Hope this helps.
Nancy
Of bakerprovan
Sent: Thursday, January 26, 2006 11:02 PM
Subject: [Vantage] Subreport wont display in vantage
hello to all,
display.
Yahoo! Groups Links
Nancy,
Rebecca
Dunn, Nancy
Sent: Friday, January 27, 2006 10:26 AM
I don't know if this could be the same thing, but when we converted to 6.1,
I had problems with some forms. The detail on the invoices and checks on
Support had me reinstalled Crystal 8.5 then only installed the patches from
Epicor (MFG6\Crystal folder) that took Crystal to version 8.5.2.718. The
details showed up then. (I was on a higher version) Hope this helps.
Nancy
bakerprovan
hello to all,
I am having problems with viewing a subreport in a main report(using Crystal
Reports 8.5) in Vantage 6.1, I am trying to figure out if the link between
the database and report is broken but when I checked it seemed alright. I
have viewed the report already but cant anymore. I have browsed the data
fields I've used and found the right contents to display.
Yahoo! Groups Links
Yahoo! Groups Links
Rebecca,
them a call anyway.
Nancy
Crystal Reports 8.5
our FTP site.
applied to your CR 8.5 program, in the following order:
that will be doing the developing and designing of the reports. It is
almost never installed on the server. The installation is very
straightforward, you will install it to the default location which is
C:\Program Files\Crystal Reports.
are:
Of Rebecca Schmuck
Nancy,
8.5.0.217, and that was after downloading the patch this morning that
was on EpicWeb.
Rebecca
