Thanks for the suggestion Brian.
Turns out that it was a vantage menu security configuration issue.
All is back to normal again.
Neil
Neil
--- In vantage@yahoogroups.com, "Brian Roberts" <broberts@...> wrote:
> Check menu security on your menu item (Menu Maintenance, probably under
> Process, then Security tab). An alternative is that menu item has been
> deleted but is still referenced in your client configuration files.
> Brian.
> Of too_much_hg
> Sent: Wednesday, June 15, 2011 4:55 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Suddenly getting Errors starting and ending
> Production Activity
> The error message is ...
> Menu ID: USDTPROD not valid for the current user
> Any idea what would suddenly cause this ?
> I have stopped everything in Open Edge and Rebooted the Server.
> Still getting this error.
> I don't see anything in the logs, what should I look for ?
> Thanks,
> Neil
