Switching tabs event?
Hi guys,
Once again stuck on a problem I hope someone can enlighten me on!
Upgrading one of the classic dashboards. Multiple top level grids (organized as a Panel Card Stack of each having a grid) used as a publisher grids. They come from different BAQs and need to pass data to subscriber grids (many of them). My issue is I cannot find a way/event to refresh data in subscriber grids when I simply change top level tabs.
Goal is:
Switch top level Tab → Focus on First row in the grid → Fire events that refresh data in lower grid(s)
Something like that worked like a charm in E10 as there were plenty of various events in Infragistics libraries to do similar things in C#…
P.S. I can achieve this by adding a view for each subscriber multiple times, so it can natively subscribe to one and only top grid, but there are 36-40 of these grids required instead of 6-8 if I can get dynamic approach to work.
Any help and advise would be appreciated.
There is no event for switching tabs.. Which is pretty rubbish!
You can create a button to tell TransView what tab is currently live then off that event refresh all subscribers.
