In Vantage 6, the Epicor provided Crystal reports do not use ODBC -
their statement is correct. Instead Vantage 6 creates several temporary
files on the client's local hard disk, and Crystal works from those. In
version 8+, these have become XML files in the shared EpicorData
directory.
If you customized reports in Vantage 6, these will very likely be ODBC
and you'll see the password prompt. Its actually recommended to create
a separate read only username for ODBC reports instead of using the
sysprogress name. That might be worth setting up now if you're changing
security & passwords.
There is no system agent in Vantage 6 nor scheduled reports.
Brian.
Of shraderc
Sent: Tuesday, March 13, 2012 4:59 PM
Subject: [Vantage] Re: sysprogress Password change
I don't think Vantage 6.10.543 has a 'system agent' - we have a fairly
old setup here... Someone correct me if I'm wrong.
The EpicorData directory doesn't look very familiar...
Chuck
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Zac
Jason Woodward <zac@...> wrote:
agent is the only place that has to know a password. When a crystal
report is run from within vantage an XML file is output to the
EpicorData\Reports\<useID>\ and the crystal client is told how to read
it using the defined report.
Behalf Of shraderc
password, which is perfectly fine. However, in Vantage, reports never
seem to require a password. I spoke with a rep at Epicor today and she
stated that this is because unmodified Vantage reports do not use ODBC,
and that's why we never have to type in the password. I consider this
statement suspect...
don't have to type in the password every time we run a Vantage report
that is relying on Crystal Reports technology? (I think the Job
Traveller is one such report).
directory.
Brian.
Of shraderc
Chuck
>ODBC or if you are doing a dump and load. Within Vantage the system
> My limited understanding is that the sysprogress is only used with
>experienced industry experts.
> "Zac" Jason Woodward
> Network Administrator
> Intermountain Electronics, Inc.
> O: 877-544-2291
> M: 435-820-6515
> F: 435-637-9601
> www.ie-corp.com
> Creating customer confidence through extraordinary service and
>[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
Behalf Of shraderc
> Sent: Tuesday, March 13, 2012 2:07 PMhave figured out how to do it in the Progress 'Database Admin' tool.
> Subject: [Vantage] sysprogress Password change
> Greetings again!
> I'm hoping to change our password for the account 'sysprogress' and
>required to type in the 'sysprogress' username and corresponding
> Currently, users running external Crystal reports (8.5) via ODBC are
>somehow need to indicate to Vantage what the new password is so that we
> We use Vantage 6.10.543. If I change the sysprogress password, will I
>[Non-text portions of this message have been removed]
> Thanks for any help...
> Chuck Shrader
> AMI
> Oak Ridge, TN
