System Monitor Error
Images don't come through on the board, so no one knows what those errors
look like.
However, if you literally only have those two menu items available to them,
then that is your problem, you need to make sure all users can see and
access the System monitor through menu maintenance otherwise you will get an
error similar to what it seems like you have described.
Hellings, Lauren
Sent: Friday, March 16, 2012 9:20 AM
Subject: [Vantage] System Monitor Error
I have created a custom folder with a custom security code in the main menu
tree for our HR department because they only need access to employee setup
and employee badge. When the HR users log in, they are able to see the two
screens that they need, but they receive the error message below and the
system monitor doesn't start. Which means they cannot print the employee
badges. These users are created the same way all other users are created and
have the same rights on their computers. Has anyone seen this issue before?
[cid:image001.jpg@01CD034D.745FE860]
[cid:image002.jpg@01CD034D.745FE860]
Thank you,
Lauren Hellings
Business Analyst
Cell: 832-472-1736
email: lauren.hellings@...<mailto:lauren.hellings@...>
www.c-p-i.com<http://www.c-p-i.com/>
----------Legal Disclaimer----------
The information contained in this message may be privileged and
confidential, and is intended solely for the use of the named addressee. No
other person is authorized to access, copy or re-use this message (or any
information contained herein). If you are not the intended recipient,
please notify us immediately by replying to this message and delete it from
your computer.
I have created a custom folder with a custom security code in the main menu tree for our HR department because they only need access to employee setup and employee badge. When the HR users log in, they are able to see the two screens that they need, but they receive the error message below and the system monitor doesn't start. Which means they cannot print the employee badges. These users are created the same way all other users are created and have the same rights on their computers. Has anyone seen this issue before?
Thank you,
Lauren Hellings
Business Analyst
Cell: 832-472-1736
The information contained in this message may be privileged and confidential, and is intended solely for the use of the named addressee. No other person is authorized to access, copy or re-use this message (or any information contained herein). If you are not the intended recipient, please notify us immediately by replying to this message and delete it from your computer.
