System Time != Log Time
What tells Epicor what time to log in log files? I am seeing a difference of 6 hours - I assume it is set to GMT time, although the server itself is set to the proper timezone and time. Any thoughts?
Yeah this is an old “bug” it records GMT you have to do math :slight_smile:
Well drats, so much for using the automailer as is. Think you can help me with the formula :laughing:
I’ll refer you to this awesome website I found the other day which can help with these things
SMIRK :wink:
PS: If that website doesn’t help let me know what you are trying to do exactly. (What do you mean by automailer)
Was just kidding, I’m going to use your mailer code :smiley:
I guess automailer is the wrong term, I meant the mailer object you can drop onto BPMs. Was going to use that and insert in but I am not sure that I can do math on those fields in that method so I’ll just go with the code option.
