TAB versus CTRL-I in Vantage 8
Stan Chmura wrote:
> In the config files of 8.0, you can change the TAB to ENTER for advancing to
> the next input field. Will code 39 read "Enter" like it does CTL-I?
Same thing, $M in code 39 is translated to CONTROL-M rather than ENTER.
But I found a setup barcode for our Symbol LS 2208 barcode scanner that
will make it generate real TAB, ENTER, ESC etc. keys. Works with Vantage
just fine, so I'm happy.
Pim
Vantage 6, like most applications, allows one to use either TAB or CTRL-I
for advancing to a next input field. Although the low-level scancodes are
different, they produce the same input character with decimal value 10.
Similarly, both SHIFT-TAB and SHIFT-CTRL-I both shift input to the previous
input field.
Vantage 8, however, only accepts the actual TAB key.
Why should I care?
Well, we are using barcode scanners in extended CODE 39
mode. This mode allows one to embed non-printable characters, such as
CTRL-I as "$I". Using this technique, one can print barcodes that fill
multiple input fields in a single scan.
It took us a while to figure out why this technique stopped working in
Vantage 8.
Does anybody know a workaround?
Macroscoop BV
Pim Zandbergen
_____
Pim Zandbergen
Sent: Tuesday, May 01, 2007 8:40 AM
Subject: [Vantage] TAB versus CTRL-I in Vantage 8
input field.
Why should I care?
Vantage 8.
Macroscoop BV
Pim Zandbergen
