Here’s a strange one for you all. So Quote Entry, Lines, Worksheet. Tabbing was all over the place so I customized and set the TabIndex property for all fields on the form. It works beautifully with no quote loaded in… Once you load a quote or create a new quote, the tabbing is all over the place again. And, strangely, off exactly as it was before I customized it. And yes I can assure you that the customization IS loading. If I reset the form clearing the quote out, tabbing is back to perfect…
I kind of remember running into some “built-in” navigation in quote entry before.
Where some of my custom property settings were being overridden by some internal Epicor code. In my case I think it had more to do with setting focus on controls but… now I’m wondering if the same thing could be happening on your sheet(s)?
