# Table field for Default Report Style? **Category:** [Epicor ERP 9](https://www.epiusers.help/c/e9/7) **Created:** 2016-10-24 19:36 UTC **Views:** 1222 **Replies:** 2 **URL:** https://www.epiusers.help/t/table-field-for-default-report-style/35938 --- ## Post #1 by @bordway Wonder if anyone knows the physical location for Report Style fields "Valid" and "Default"? I've haven't had luck locating from the trace or the Data Dictionary. Just references to a temp table "ReportCompany". Table: ReportStyle Field: CompanyList (this does update when "valid" is selected but where to look for "default")? Delimited list of company id's that can use this ReportStyle. Blank = All Companies. This field will not be overlaid during release upgrades. This field is not intended to be directly updatable. Instead it is exposed to the UI in a separate table (ReportCompany) which is not a physical db table. All Companies are created in ReportCompany. If in the CompanyList, then ReportCompany.ValidStyle = Yes Delimeter character is global LIST-DELIM value (~) Thanks --- ## Post #2 by @Krosell There is a table named: Ice.ReportDefaultStyle.. There is a record for each Report Style and Company with these fields: SELECT [ReportID] ,[Company] ,[StyleNum] ,[SystemFlag] ,[SysRevID] ,[SysRowID] FROM Ice].[ReportDefaultStyle] --- ## Post #3 by @bordway >>ReportDefaultStyle I was seeing that in the data dictionary but.. it wasn't being listing it in the BAQ designer? (E9) I finally got to it by looking directly at the database. Thanks. --- **Canonical:** https://www.epiusers.help/t/table-field-for-default-report-style/35938 **Original content:** https://www.epiusers.help/t/table-field-for-default-report-style/35938
