Tagging Bundles in 8.0
--- In vantage@yahoogroups.com, "Aaron Hoyt" <aaron.hoyt@...> wrote:
> I will look into how I might make this work, thanks
> More or less we have done this.
> Using AMM and data collection I generate labels that print
upon "reporting
> quantity". Employees are instructed to report quantity at
each "stack".
> The label generates a number based on the LaborDtl.LaborDtlSeq and
the time
> (seconds past midnight). The number both ensures uniqueness and
gives
> traceability without having to get into lot numbers being entered
on the
> system.
> This feature is not anything Epicor created or sponsored, but I
created it
> using only tools within the system (BAM) and wasp label software to
print
> the label. It may be a bit of a trick to convert the system over
to 8.0,
> but for now on 6.1 it works slick.
> Let me know if you need more details.
> Aaron Hoyt
> Vantage Plastics
> -----Original Message-----
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On
Behalf
> Of mmcwilliams22
> Sent: Tuesday, March 07, 2006 10:27 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Tagging Bundles in 8.0
> We are implementing 8.0 and we give every bundle of material we
create
> a unique sequential number. There are multiple bundles with varying
> amounts of pieces in a job, but we Produce, and schedule by the
foot or
> piece. Is anyone out there creating bundle tags successfully ( with
> our current system the lot number is the tag number and every
bundle is
> a new lot).? Our PM says it will require custom code.
We are implementing 8.0 and we give every bundle of material we create
amounts of pieces in a job, but we Produce, and schedule by the foot or
our current system the lot number is the tag number and every bundle is
Using AMM and data collection I generate labels that print upon "reporting
quantity". Employees are instructed to report quantity at each "stack".
The label generates a number based on the LaborDtl.LaborDtlSeq and the time
(seconds past midnight). The number both ensures uniqueness and gives
traceability without having to get into lot numbers being entered on the
system.
This feature is not anything Epicor created or sponsored, but I created it
using only tools within the system (BAM) and wasp label software to print
the label. It may be a bit of a trick to convert the system over to 8.0,
Aaron Hoyt
Vantage Plastics
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of mmcwilliams22
