We have a task set with a number of parallel options. So at each step, a user is making a selection from one of several options until the path is complete.
We have encountered a situation where the user is selecting the correct next step (we can see it in the Task Detail) but the task tree is showing something completely different.
The flow should be (by sequence number):
20 → 40 → 4000
Instead it appears to be:
20 → 40 → 51
The user is selecting task 4000, but task 51 is appearing in the task tree as the next task. Details in the attached .pdf
TaskSetNotMovingToNext.pdf (166.8 KB)
Thanks for any insight you can provide!
