E9 Support confirmed that the current_value field can be reset to 1 using SQL. Doing so has corrected the issue.
Now to find out how the value went to NULL in the first place.
--- In vantage@yahoogroups.com, "robertbeaghan" <robert.beaghan@...> wrote:
> We started receiving various printing errors yesterday. It appears that the XML report data files all have a sequence of 00000, e.g. "Packing Slip Print00000.xml".
> In the database, field _SEQT_tempfilenum.current_value is showing as NULL. After some tests in our test environment, I'm pretty sure that the current_value didn't cycle back to zero properly.
> Has anyone else encountered this issue? Is it safe to update this field back to 0 directly with SQL? Or is there a conversion program to run that will correct the issue?
> Thanks,
> Bob Beaghan
