Tim,
on behalf of Erik and myself thanks for your reaction.
We have not solved the problem yet. When we find the cause then we will post
it on egroups.
Ronald van der Linden
Macroscoop.
Sent: woensdag 18 oktober 2000 17:58
To: vantage@egroups.com
Subject: Re: [vantage] Terminal server installation
Erik,
I'm not sure why you are having performance issues. If you
run with only one user on the system, is it the same way?
Do you map any drives in the terminal server login? Is the
Vntgwork directory in the Terminal server users directory?
I'm just guessing now, I'm not sure why. There is a website
thethin.net, that has a searchable archive of messages you may
want to try. Good luck
Tim Care
Electro Chemical Finishing
it on egroups.
Macroscoop.
Erik,
Tim Care
----- Original Message -----
To: <vantage@egroups.com>
Cc: <ecfmis@...>
Sent: Wednesday, October 18, 2000 7:21 AM
Subject: RE: [vantage] Terminal server installation
> Tim,
> I'm running this at one location,
> Vantage 4.00.815 and Progress 9.0b37 are installed on a stand alone
server,
> Terminal Server on another, both are located at the same place same
network.
> The ClientSetup was done on the Terminal Server with the add/remove
> programs.
> Spec TS Dual Pentium II 333Mhz 400MB
> Vantage server Compaq 730Mhz 256MB RAID 1
> From: Tim Care [mailto:ecfmis@...]
> Sent: vrijdag 13 oktober 2000 20:45
> Are you running this in one location?, multiple locations?
> Is the Terminal server located at the same place as the
> Vantage server? What version of Vantage? Did you
> install the Progress client on the Terminal Server?
> Our installation works fine, in fact, some users would
> rather run vantage on the old 486 Upgraded PCs than
> on Brand new Pentium III 550 MHz machines, because
> it is faster.
> If you have any more details, you may want to post them
> to see if anyone else has an answer.
> Tim Care
> From: <R.van.der.Linden@...>
> Sent: Friday, October 13, 2000 10:23 AM
> Subject: [vantage] Terminal server installation
> > we have installed vantage on a server through a terminal server
> > server, but it performs badly. it is very slow, it takes minuts to
> > start vantage and printing is even slower.
> > when we start vantage from a client without using terminal server we
> > have no performance issues at all.
> > Does anyone have an idea what could be the case here?
> > specs:
> > terminal server server:
> > pentium II dual processor 330 mhz
> > 400mb ram
> > vantage server:
> > compaq proliant ml 350 pentium III 750 mhz
> > 256 mb ram
> > raid 1, 4 disks
> > thanks,
> > We no longer allow attachments to files. To access/share Report Files,
> please go to the following link: http://www.egroups.com/files/vantage/
> > (Note: If this link does not work for you the first time you try it, go
> to www.egroups.com, login and be sure to save your password, choose My
> Groups, choose Vantage, then choose Files. If you save the password, the
> link above will work the next time you try it.)
to
Groups,
> choose Vantage, then choose Files. If you save the password, the link
above
