You need to walk through scenarios to pinpoint the slowness.
1. Is Vantage slow on the terminal server when you login to the
console and run it locally on the server?
a. If yes, then that is the source of the problem where you can
continue on. Check the perfmon utility to see if the server has enough
memory, cpu, disk utilization, etc...
b. If it is memory, great, add more. Terminal servers can consume
memory easily especially if you are running other apps on them besides
vantage.
c. Is it a network bottleneck? Are you running at a speed of 100MB
instead of 1000 even though you are connected to a 1000 port switch. It
could be you are plugged into the wrong port, your server card is only
100MB or auto-negotiate isn't working correctly in which case you should
set the server nic card and the switch port to run at 1000. Also when
using ESX you should check your VM configurations to make sure you are
getting the full network speeds your environment supports.
d. Check to see also that you are giving the VM the proper number
of processors. If your ESX server has a quad core are you allowing all
four cores to go to the VM? Also check the bios for hyper threading and
read up on terminal servers and hyper threading. Do the same for your
database server.
e. If it is the disk read/write speeds you may need to rethink your
RAID configurations and type of hard drives you are running. You may be
running 10K and may need to upgrade to 15K. You may be running ATA and
should upgrade to SATA or SATA II or SCSI.
f. Is it a problem with the database setup? Try running vantage
locally on a client that has the closest hardware specs in terms of
memory and nic speeds as the server and see if it is better or worse.
You may need to tweak the database settings for your environment.
msprowles@...]
Sent: Thursday, March 12, 2009 9:39 AM
To:
vantage@yahoogroups.com
Subject: [Vantage] Re: Terminal Server Speed and other issues
Yes, we are using ESXi to run three terminal servers on three different
physical boxes. None of the other virtual machines that run on these ESX
boxes are heavily hit, most are just low grade servers systems that
needed to go somewhere. We have just changed the Processing delay to 3
seconds we will see if that helps.
Does anyone else have any suggestions on how to best setup Vantage
Clients on Terminal Server? We are still trying to speed this up further
as it is still really slow.
--- In
vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
"hessd3" <hessd3@...> wrote:
> I assume by ESX you mean the VMWare hypervisor. If you are having
problems with printing, I would concentrate on the System Agent. Double
check the port setup and set the Processing Delay to a lower number like
2 or 3 seconds for printing. This is the delay before the CR report is
processed. Our initial setup was for 20 seconds, not cool. Also some
report like the Scheduled Shipments dump a huge number of shipments when
you run them. Our .xml file is currently at 80MB and grows by 100KB/day.
The Crystal Report then has to parse that 80MB of data to show a one
page report.
