Terminating user session
Patrick, you get a gold star for better instructions :)
Frank Zeigafuse
Innovative Office Products
General Manager
Direct Phone: 610-559-6369
Email: fzeigafuse@...
Sent: Tuesday, May 24, 2005 2:53 PM
Subject: RE: [Vantage] terminating user session
Request a document from epicor on how to setup PROMON on your server. If its
already setup you want to run PROMON.
Select item 8 "Shut Down Database". (don't worry your not going to
shut it down.)
You will get a list of all sessions running.
Select 1. Disconnect User.
Enter the session number listed in the first column under "usr".
Enter x to exit.
Enter q to quit. (Promon)
Patrick Winter
Michelle VonBokern
Sent: Tuesday, May 24, 2005 1:39 PM
Subject: [Vantage] terminating user session
Hi all. I need to know how to cancel a user session in vantage 6.1. Where to
go, what to do? I have a user who is not logging out correctly from home on
terminal services resulting in him showing as having multiple sessions
running. Temporarily I have allowed him more than one session at a time, but
for example right now he is using 3 licenses because of two terminal
sessions showing up on top of the actual session he is using in the office
right now. We have limited amount of licenses and he is blocking other users
from access.
Help please?
Thanks-
Michelle Von Bokern
Office Manager
Advance Engineering Co.
PH: 630-628-3445
FAX: 630-628-3449
mvonbokern@... <mailto:mvonbokern@...>
Yahoo! Groups Links
Yahoo! Groups Links
Where to go, what to do? I have a user who is not logging out correctly
from home on terminal services resulting in him showing as having
multiple sessions running. Temporarily I have allowed him more than one
session at a time, but for example right now he is using 3 licenses
because of two terminal sessions showing up on top of the actual session
he is using in the office right now. We have limited amount of licenses
and he is blocking other users from access.
Help please?
Thanks-
Michelle Von Bokern
Office Manager
PH: 630-628-3445
FAX: 630-628-3449
If its already setup you want to run PROMON.
shut it down.)
Enter x to exit.
Patrick Winter
Michelle VonBokern
Where to go, what to do? I have a user who is not logging out correctly from
home on terminal services resulting in him showing as having multiple
sessions running. Temporarily I have allowed him more than one session at a
time, but for example right now he is using 3 licenses because of two
terminal sessions showing up on top of the actual session he is using in the
office right now. We have limited amount of licenses and he is blocking
Help please?
Thanks-
Michelle Von Bokern
Office Manager
PH: 630-628-3445
FAX: 630-628-3449
Yahoo! Groups Links
Promon shortcut
8 shutdown database I think
1 disconnect user
Then the user id
Frank Zeigafuse
General Manager
Sent: Tuesday, May 24, 2005 2:39 PM
from access.
Help please?
Thanks-
Michelle Von Bokern
Office Manager
PH: 630-628-3445
FAX: 630-628-3449
Yahoo! Groups Links
Thanks Frank and Patrick - appreciate it!
Michelle Von Bokern
Office Manager
PH: 630-628-3445
FAX: 630-628-3449
mvonbokern@...
Of Frank Zeigafuse
Sent: Tuesday, May 24, 2005 1:55 PM
Promon shortcut
1 disconnect user
Then the user id
Frank Zeigafuse
General Manager
Where to
on
but
office
users
from access.
Help please?
Thanks-
Michelle Von Bokern
Office Manager
PH: 630-628-3445
FAX: 630-628-3449
have
and
Yahoo! Groups Links
Yahoo! Groups Links
This is what they sent me.
Chris Stover
Business Control Engineer
Deaver Industries
205-426-4309 Voice
205-426-4364 Fax
cstover@...
www.deaverind.com
Michelle VonBokern
Help please?
Thanks-
Michelle Von Bokern
Office Manager
PH: 630-628-3445
FAX: 630-628-3449
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
<http://docs.yahoo.com/info/terms/> Service.
