I am still trying to remember the setting for 3.0 (it's been a while) but it
is the DLC= that must be run to tell the system where to find the progress
version you are using.
On the test environment you will have to set DLC= (then the pointer to the
8.3 install) and then I believe you will have to call out the full path and
file name of the version you are using to restore.
This should have you on the path at least. It has been to long for me to
give more details.
Aaron
Sent: Friday, September 26, 2003 1:42 PM
Subject: RE: [Vantage] TEST SERVER/DATABASE
I think you may have something here. The live server is still on progress
8.3 but the test server is on progress 9.0. How can I be sure what is
running on the server. I know that they are both installed on the test
server. I have the progress 8.3 and in procontrol it is active. The progress
9.0 in procontrol there are no services active.
Jim
give more details.
Aaron
Jim
> -----Original Message-----Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> From: Aaron Hoyt [mailto:aaron.hoyt@...]
> Sent: Friday, September 26, 2003 12:13 PM
> Are you using the same version of progress to restore as you are
> running the
> live database on?
> From: Jim Frice [mailto:Jim.Frice@...]
> Sent: Friday, September 26, 2003 1:09 PM
> I copied the backup to the test server through windows explorer. I then
> tried to do a prorestore from the c:\epicor\progess\bin and I received the
> following error
> Progress Patch Version 9.0B10 as of September 23, 1999
> SYSTEM ERROR: CRC failure on backup header block (1058)
> !!!ERROR - Database restore utility FAILED!!! (8564)
> Anyone have any ideas.
> Jim
> > From: Todd Caughey [mailto:caugheyt@...]
> > Sent: Friday, September 26, 2003 11:06 AM
> > When I did this I just copied the backup.1 (or whatever it is
> > called) file to the test server and restored it there. I've
> > burned the backup.1 file to CD several times for Epicor to
> > restore and examine our DB at their site.
> > -Todd C.
> > Sent: Friday, September 26, 2003 11:02 AM
> > To: Vantage@Yahoogroups. Com
> > Subject: [Vantage] TEST SERVER/DATABASE
> > Hello Vantage gurus,
> > I have added a test server to our network for vantage testing of new
> > releases. I am now trying to get the 3.0 database copied over
> to the test
> > server. On the test server I have 3.00 and 4.00 installed but I
> can't get
> > the backup of the 3.0 database over to the test server. How do I get the
> > backup file from the one server on the network to the other
> server. Can I
> > copy using the windows explorer? Should I do a prorestore? Do I
> > need to map
> > to server where the backup is? Any help would be appreciated.
> > Jim Frice
