I went ahead and cleaned out the directory, no change. In the log files I get the following,
[12/02/21@14:02:30.688-0600] P-001968 T-003516 1 AS -- Logging level set to = 1
[12/02/21@14:02:30.688-0600] P-001968 T-003516 1 AS -- No entry types are activated
[12/02/21@14:03:43.531-0600] P-004180 T-001056 1 AS -- ** Invalid character in numeric input M. (76)
[12/02/21@14:03:43.531-0600] P-004180 T-001056 1 AS -- Incompatible datatypes found during runtime conversion. (5729)
[12/02/21@14:03:43.531-0600] P-004180 T-001056 1 AS -- Routine <Remote Client> sent called routine Sync lib/SessionMod/Sink.p mismatched parameters. (2570)
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jose Gomez
Sent: Tuesday, February 21, 2012 1:50 PM
Subject: Re: [Vantage] test server error
Look in your \Server\Logs\ it gives you more detail, my guess it has
something to do with a corrup .P in the BPM folder, if that's the case
Rip out anything in \\mencken\Epicor905\BPMExec\LiveBPM\bo\BONAME\.p
This should be re-created when you restart your app server (Replace LiveBPM
with whatver instance you are on)
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Tue, Feb 21, 2012 at 2:44 PM, Stephen Freeman <stephenf@...> wrote:
> I'm getting a test server up and running and I'm getting the following
> error at login. I'm running Epicor 9.05.605. I've copied over a backup from
> my live server to my test server both are running the same versions. Any
> ideas?
> ERROR condition:Routine <Remote Client> sent called routine Sync
> lib/SessionMod/Sink.p mismatched parameters. (2570) (7211)
