Joanne,
I have been told by development that clicking yes will not corrupt
your database. We did so many times on both our live and test
databases and never had any problems. I later found out there is a
document on resolving this error message. Contact support and ask
for Page 6293MPS. It is very detailed and should take care of your
problem. Also, from my understanding, this happens when you select
English/United States instead of English/USA II (that is not
mentioned in the doc).
Hope this helps.
Cheers!
--- In vantage@yahoogroups.com, "Joanne Yargeau" <jyargeau@t...>
Hope this helps.
Cheers!
wrote:
>go
> We changed the .ini file to the UNC format and now when I try and
> into the admin tools I get the following error:then
> 'Your database codepages does not match your session code pages.
> This could potentially cause database corruption. Do you want to
> continue?'
> Since this is only a test server, I clicked yes to continue and
> I can get into the admin tools. But obiviously there is stillwrote:
> something wrong. Can anyone offer help or suggestions in resolving
> this? TIA
> --- In vantage@yahoogroups.com, "Gerard Wadman" <gwadman@s...>
> >and
> > From the Icon properties, in the target field make sure that the
> path to
> > the mfgsys.ini file is in UNC format.
> > Then on the Vantage sever browse to
> > <drive>:\epicor\mfgsys\server\config\mfgsys.ini, edit the file
> makeenvironment
> > sure that the DLC path is also in UNC format.
> > Ie
> > DLC=\\my_server\epicor\oe100b
> > ________________________________
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On
> Behalf
> > Of Joanne Yargeau
> > Sent: Thursday, January 19, 2006 11:09 AM
> > Subject: [Vantage] Test Server Vantag 8 error
> > We have Vantage 8.00 804b installed on a test server. I can get
> into
> > the application and the MES program. However I get the following
> error
> > for both Admin Tools and the Schema Changes: 'The DLC
> > variable must contain a valid directory/path(11002).' This errorTech
> > occurs on the client machine not the server. Can anyone who has
> > installed version 8 offer any help in fixing this. Contacting
> > support has yielded no results. As always thanks for any help.
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> must
> > have already linked your email address to a yahoo id to enable
> access. )
> > (1) To access the Files Section of our Yahoo!Group for Report
> Builder
> > and Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > <http://groups.yahoo.com/group/vantage/files/>
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/links
> > YAHOO! GROUPS LINKS
> > * Visit your group "vantage
> > <http://groups.yahoo.com/group/vantage> " on the web.
> > * To unsubscribe from this group, send an email to:
> > vantage-unsubscribe@yahoogroups.com
> > <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> > Service <http://docs.yahoo.com/info/terms/> .
