Testbed Server Questions
This was my check list/notes. Some of it is dated now. It is just a
supplement to Epicor's installation instructions.
Hope it helps.
Patrick Winter
sSc Specialty Screw Corporation
Vantage 5.00.338, Progress 9.1a
Notes for the record. Vantage 5 Installation, By Patrick Winter
I. Vantage 5.0 Installation Notes:
A. Test Network:
1. Notes:
a. Map M: drive for new release, Services are
Epic50 2500, epic50trn 2510, ssctrain 2520, sscaudit 2530
2. Pick the patch level to jump to: 5.00.317
3. Download patch, source, write file, get source code
pass word
4. Review program Modifications: (I use MKS Tool Kit
to cut copy & paste)
5. Purchase and Install - "Component Tool Box - OCX".
6. Convert Report Builder Reports.
7. Convert Crystal Forms & Test. (For both companies).
8. Review Security and Setup groups ahead of time.
9. Review Company Configuration changes with Accounting
on (Both Companies)
10. Review the NT server AT commands for backups and
document.
11. Backup reports, crystal forms, employee pictures.
12. I have install AutoVue on another server so it never
gets effected with upgrades by epicor.
B. Day before conversion.
1. Close out open packing slips. Open items etc...
(Both Companies)
C. Actual Day of Conversion on Live Network.
1. Stop the NetLogon Service.
2. Stop the Sharing on the version 4 folder, "Epicor."
3. Run the VanBack.bat to backup the data base.
4. Stop "AT" commands for backups.
5. Stop Seagate Backup Exec backup routine you don't
want it to backup the new live database.
6. Disable any virus scanning software on this server.
7. Reboot.
8. Install Vantage & Progress from CD.
a. Install Progress 9.1A
b. Install Progress 9.1A patch 9.1a24
c. Install eManufacturing 5.00.301 Software
d. Install eManufacturing 5.0 Client (on the
first PC & Save Default Values).
(1) Now use the system to install other
clients without logging on yet.
e. Upgrade Database From Vantage 4.0 Morocco
Application.
(1) Backup 4.0 database
--------------------------------------10 minutes
(2) Copy and restore to 5.0
(3) INDEX
rebuild-------------------------------------------------2 hours
(4) Turn off crash protection
(5) Run SCHEMA CHANGES
-------------------------------- 4 hours
(6) Turn on crash protection
(7) Licence Codes
-----------------------------------------------15 minutes
(8) Database conversion on first
login----------------------2-1/2 hours
D. Get Patches up to date for Vantage and Progress.
1. Install Progress Patches 9.1a26
2. Install Latest Vantage Patches 3.00.317
a. May have more schema changes on first login.
-------------2 hours.
E. Upgrade Each Client PC.
--------------------------------------------15 minutes each (2 hours)
1. Shop Floor Stations, Sales, Production, Shipping,
Tool Room, Accounting, Wire Room
F. Put in all SSC Modifications.
1. Move Program modification into place.
-------------------------------- ½ hour
2. Copy over Report Builder Reports and Test.
-------------------------½ hour
3. Copy over Crystal forms and Test. (Both Companies)
------------ ½ hour
4. Company Configuration setup for new modules.
5. Security Setup in Vantage, Groups, Users, new
security codes, etc... (4-6 hours)
6. Create Tables References in Data Dictionary
--------------------------- 1 hour
7. Review Progress Backup procedure. create new batch
files, set server AT Commands. (2 hours)
8. Review Seagate Backup Exec, skip new database files
& bi file.
II. Issues:
A. Securing Vantage Files with NT Security. (Handout) Todds
Email is better. (2 hours)
B. Create Training Database.
C. Create Auditors Database.
D. Add Progress Time Out Feature.
E. Setup Mike Podlin's Autorpts.
F. Update the help files from epicor downloads. Help.exe
Sent: Tuesday, July 23, 2002 1:42 PM
To: 'vantage@yahoogroups.com'
Subject: [Vantage] Testbed Server Questions
I have finally got NT 4.0 installed on a server which will be a testbed for
converting from Vantage 4.0 to 5.x and then allowing users to preview the
changes before we try to go live (and me to start converting RB and
Crystal). I have a couple questions because I did not do the original
Vantage install so have not done this process before.
1. Are there instructions around somewhere for this? I could not find
anything useful in the readme.wri on the V4.00 CD. I might need to call
support I suppose.
2. Do I install Progress first or Vantage first?
3. I have some patch files I have applied to our current live version. Can
I install Vantage then just the lat4est patch for our current live system
and be able to use a restore of that DB as a test DB on the new server?
4. Any other notable "gotchas" in a 4.0 install that I need to watch our
for?
Once I get a duplicate of our current situation running my next steps will
be to convert to 5.1, for which there are plenty of previous groups messages
to guide (or confuse) me.
-Todd Caughey
Harvey Vogel Mfg. Co.
support I suppose.
for?
-Todd Caughey
Hi Todd,
#1. I Don't have that doc anymore.
#2. You install Progress first, then Vantage.
#3. The easiest way is to restore a backup to your new directory location. Then just apply the latest patch. You can do these two steps in reverse order as well.
#4. Might be a good time for a Dump & Load as well... before the conversion.
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Tuesday, July 23, 2002 11:41 AM
support I suppose.
for?
-Todd Caughey
Yahoo! Groups Sponsor
ADVERTISEMENT
