Ok so thats working. The only thing remaining would be that when a new line is added and hold is checked the created row is unfirmed and when hold is unchecked a firm release is created. Tried adding another condition for changed row but that didn't seem to work? Any other way I can just get it to default. All I see run in my tracelog is the MasterUpdate method
--- In vantage@yahoogroups.com, Waffqle <waffqle@...> wrote:
> If you go to conditions you can set it to only fire when 'the value of
> <field> has changed from <something> to <something else>' you can use this
> to ensure your BPM only fires when the field is changed. However, that won't
> stop it from firming/unfirming all releases. If you only want to change a
> subset of the releases, you're going to need to come up with
> some criteria that you can implement.
> On Tue, Sep 13, 2011 at 2:13 PM, jgiese1988
> <jgiese@...>wrote:
> > Hmm.... actually this won't work. So how would I go about making this be
> > controlled at the time the hold checkbox is checked? The issue is if we
> > actually want the order off hold and one of the releases unfirm while the
> > other is firm at the time i save it will firm the unfirm release. Can I add
> > a condition at the BPM that only runs the action if the value of orderHeld
> > changes?
> > --- In vantage@yahoogroups.com, Waffqle <waffqle@> wrote:
> > > As far as your issue with the order holds, try this:
> > > FOR EACH ttOrderHed,
> > > EACH OrderRel WHERE OrderRel.Company = ttOrderHed.Company AND
> > > OrderRel.OrderNum = ttOrderHed.OrderNum.
> > > IF ttOrderHed.OrderHeld = TRUE THEN OrderRel.Firm = False.
> > > ELSE OrderRel.Firm = TRUE.
> > > END.
> > > Double check the field names, as I'm just pulling them off the top of my
> > > head here.
> > > Essentially what you're doing is finding all the Order Headers (there
> > should
> > > only be one). Generally speaking, if your accessing tables that Epicor is
> > > using for the current operation, you'll need to work with the temp ('tt')
> > > table instead of the actual DB table. This ensures that you're working
> > with
> > > the current data even though it may not be committed yet.
> > > After we find the header, we're looking up the Order Releases. Epicor
> > does
> > > not always load all the child records into the tt dataset if they haven't
> > > been changed; this is why we're not accessing them via ttOrderRel. We
> > want
> > > to make sure we get ALL the releases. The IF statement should be pretty
> > > straight forward.
> > > In regards to what customization method to use at a given time it's not
> > > always a black and white thing and everyone has their own opinions.
> > Here's a
> > > rough overview of my views:
> > > BPM - If you want to change the way Epicor acts in all occurrences of a
> > > situation, use a BPM. If you attach a directive to a method (i.e.
> > > SalesOrder.Update) it will fire EVERY TIME that method is called,
> > regardless
> > > of where it is called from. This includes calls from Service Connect,
> > custom
> > > code, 3rd part addons, etc. Generally speaking, if the changes you wish
> > to
> > > make are purely 'business process' issues, you should try to use a BPM if
> > at
> > > all possible. BPM is generally my preferred place to customize when it's
> > > available. If you change something via BPM, you can be pretty confident
> > that
> > > it will work across the board, for all users, in all screens. The code is
> > > generally simpler and more quickly written. All you need to write is your
> > > logic, no UI code, no wiring up adapters/BOs etc.
> > > Screen Customization - There are best used for 'User Experience' issues.
> > If
> > > your users need to see more data, less data, a different UI, this is the
> > > tool. Want to create new buttons that implement user directed logic, this
> > is
> > > the place. As a rule of thumb, avoid implementing Business Logic here
> > > whenever possible.
> > > BAQ - These are just queries. If you need fetch data for dashboards or
> > > reports, these are the tool. In some scenarios you'll use them as part of
> > a
> > > screen customization, but that's a bit much to get into right now.
> > > On Tue, Sep 13, 2011 at 10:36 AM, cooner_55421 <cooner_55421@>wrote:
> > > > > I'll second the answer below.
> > > > Me too, I've been trying to improve my ABL.
> > > > BPMs ended up being the best place I found, even though they can
> > consume
> > > > quite a bit of time to set up and test.
> > > > Also, you can check out the .p programs examples here
> > > > \\servername\epicor_directory\server\ud\Test
> > > > --- In vantage@yahoogroups.com, "Brian Roberts" <broberts@> wrote:
> > > > > I'll second the answer below... I'm a couple months into learning ABL
> > > > > BPMs, and most of my time is spent figuring out what to do and how to
> > > > > hook into Epicor to do it. The technical ABL command to actually do
> > it
> > > > > is easy by comparison.
> > > > > And the BL tester (not ABL tester) is an Epicor tool for testing the
> > > > > business logic (= business objects, often abbreviated "BO"). Its on
> > > > > your Epicor server, under Utilities I think.
> > > > > It is possible to hook up the AppBuilder to your test database (add
> > the
> > > > > bits below to your shortcut) but its not that useful... do it in a
> > BPM
> > > > > instead.
> > > > > -pf "C:\Program Files\Epicor Software\Epicor905\config\mfgtest.pf"
> > > > > -ininame "C:\Program Files\Epicor
> > Software\Epicor905\config\Test905.ini"
> > > > > Brian.
> > > > > -----Original Message-----
> > > > > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On
> > Behalf
> > > > > Of Waffqle
> > > > > Sent: Monday, September 12, 2011 8:57 PM
> > > > > To: vantage@yahoogroups.com
> > > > > Subject: Re: [Vantage] Re: Testing ABL and running queries
> > > > > Easiest way to learn is just wait till you need to do something via
> > BPM.
> > > > > Then crack the manual and figure it out. Almost all of your ABL is
> > going
> > > > > to
> > > > > be written for BPMs. Getting used to what data you have available and
> > > > > when
> > > > > to run your directives is going to be trickier than actually learning
> > > > > ABL.
> > > > > --Not to say that either is a particularly daunting task.
> > > > > When you get rolling and run into a specific issue, come back to the
> > > > > list
> > > > > and we'll help you work through it.
> > > > > On Mon, Sep 12, 2011 at 7:18 PM, jgiese1988
> > > > > <jgiese@>wrote:
> > > > > > I do have the manual downloaded, printed, and in a binder.
> > > > > Unfortunately
> > > > > > 'doing' is the way I learn, so the guide really only helps as
> > > > > reference.
> > > > > > ABL tester what is that?
> > > > > > I'm hoping to use some of the examples in the guide to play around
> > > > > with the
> > > > > > training DB and see what I can all do with ABL. That's the primary
> > > > > goal. I
> > > > > > will check out the posted video next.
> > > > > > --- In vantage@yahoogroups.com, "cooner_55421" <cooner_55421@>
> > > > > wrote:
> > > > > > > Do you have the ABL manual?
> > > > > > > http://communities.progress.com/pcom/docs/DOC-16296
> > > > > > > And the BL Tester?
> > > > > > > Also, I found this video interesting:
> > > > > > > http://www.youtube.com/watch?v=4Dv295qg3FY
> > > > > > > --- In vantage@yahoogroups.com, "jgiese1988" <jgiese@> wrote:
> > > > > > > > What is the best way to go about learning ABL? I was looking
> > for a
> > > > > way
> > > > > > to maybe run queries and see the results. I believe I can do this
> > > > > through
> > > > > > app builder but I can't figure out how to use it? Any other
> > > > > recommendations
> > > > > > for learning ABL?
> > > > > *Waffqle Driggers*
> > > > > *High End Dev, System Design, Profit Drinking
> > > > > *:: 904.962.2887*
> > > > > *:: waffqle@*
> > > > > *:: NO FAXES*
> > > > > [Non-text portions of this message have been removed]
> > > > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > > > > have already linked your email address to a yahoo id to enable
> > access. )
> > > > > (1) To access the Files Section of our Yahoo!Group for Report Builder
> > > > > and Crystal Reports and other 'goodies', please goto:
> > > > > http://groups.yahoo.com/group/vantage/files/.
> > > > > (2) To search through old msg's goto:
> > > > > http://groups.yahoo.com/group/vantage/messages
> > > > > (3) To view links to Vendors that provide Vantage services goto:
> > > > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> > > *Waffqle Driggers*
> > > *:: 904.962.2887*
> > > *:: waffqle@*
> > > *:: NO FAXES*
> *Waffqle Driggers*
> *:: 904.962.2887*
> *:: waffqle@...*
> *:: NO FAXES*
