TextBox Customization How can I make it Readonly
I am a beginner and have not used the EpiViewNotification form event?
Would I add the code as a new private Sub module and
call it from the if statement?
Â
Test code does not return anything at all.
I am logging all the way out and back in to be sure to get the custom form.
Â
Doug
--- On Wed, 2/4/09, Vic Drecchio <vic.drecchio@...> wrote:
Subject: RE: [Vantage] Re: TextBox Customization How can I make it Readonly
Date: Wednesday, February 4, 2009, 10:11 AM
Have you tried putting that all in the EpiViewNotification form event?
Does the "Test Code" reveal any errors?
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of bw2868bond
Sent: Wednesday, February 04, 2009 11:03 AM
To: vantage@yahoogroups .com
Subject: [Vantage] Re: TextBox Customization How can I make it Readonly
Don't see why that would not work.
Are you actually calling SetExtendedProps( )
in the InitializeCustomCod e ?
--- In vantage@yahoogroups .com, Doug Davis <ddavis4569@ ...> wrote:
> Does anyone know how to make the textbox to be readonly.
> Setting the property of the textbox for Part.Number01 readonly =
true does not work.
> Â
> I have tried using the Script Editor following the help example
and still can not get the textbox to appear as readonly.
> Â
> This is what I was trying to use.
> Â
> To extend the properties of an EpiDataView, create the below method
and call it from the InitializeCustomCod e() method:
> Private Sub SetExtendedProps( )
> `// Get
> Dim edv As EpiDataView = CType(oTrans. EpiDataViews( "Part"),
EpiDataView)
> If edv.dataView. Table.Columns. Contains( "Number01" ) Then
> Â Â edv.dataView. Table.Columns( "Number01" ).ExtendedProper ties
("ReadOnly") = True
("Enabled") = False
> `// or to make invisible...
> `edv.dataView. Table.Columns( "Number01" ).ExtendedProper ties
("IsHidden") = False
> End if Â
> End Sub
> Thanks for any Help
> Dou
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups. yahoo.com/ group/vantage/ files/.
(2) To search through old msg's goto: http://groups. yahoo.com/ group/vantage/ messages
(3) To view links to Vendors that provide Vantage services goto: http://groups. yahoo.com/ group/vantage/ linksYahoo! Groups Links
Does anyone know how to make a text box multi-lined vs one continuous
line. I added a Text Box to a custom form and the text box is only
allowing users to continue text on one line versus ending and
continuing on the next line like what happens with Epicors comment
boxes. Any ideas on this one?? Thanks!
-Sal
Check the properties for your EpiTextBox.
MultiLine
WordWrap
Set both to true.
Of idiabos
Sent: Friday, January 23, 2009 12:41 PM
Subject: [Vantage] TextBox Customization
-Sal
The the properties of the textbox, select "Muliline" to be TRUE.
Daniel Laidig
Laidig Systems, Inc.
(574) 256-0204 ext. 229
<mailto:daniellaidig@...> daniellaidig@...
idiabos
-Sal
Thanks Daniel and Vic! Worked out great!
> Daniel Laidig
Behalf Of
> idiabos
> -Sal
Setting the property of the textbox for Part.Number01 readonly = true does not work.
I have tried using the Script Editor� following the help example and still can not get the textbox to appear as readonly.
To extend the properties of an EpiDataView, create the below method and call it from the InitializeCustomCode() method:
Private Sub SetExtendedProps()
�// Get
Dim edv As EpiDataView = CType(oTrans.EpiDataViews("Part"), EpiDataView)
If edv.dataView.Table.Columns.Contains("Number01") Then
�� edv.dataView.Table.Columns("Number01").ExtendedProperties("ReadOnly") = True
�� edv.dataView.Table.Columns("Number01").ExtendedProperties("Enabled") = False
�// or to make invisible�
�edv.dataView.Table.Columns("Number01").ExtendedProperties("IsHidden") = False
End if��
End Sub
Thanks for any Help
Doug
--- On Fri, 1/23/09, Daniel Laidig <daniellaidig@...> wrote:
Subject: RE: [Vantage] TextBox Customization
Date: Friday, January 23, 2009, 11:48 AM
Daniel Laidig
<mailto:daniellaidig@ laidig.com> daniellaidig@ laidig.com
idiabos
-Sal
�// Get
End if��
End Sub
Thanks for any Help
Dou
Are you actually calling SetExtendedProps()
in the InitializeCustomCode ?
true does not work.
> Â
> Â
> Â
> `// Get
EpiDataView)
> Â Â edv.dataView.Table.Columns("Number01").ExtendedProperties
("ReadOnly") = True
("Enabled") = False
> `// or to make invisibleÂ…
> `edv.dataView.Table.Columns("Number01").ExtendedProperties
> End if Â
> End Sub
> Thanks for any Help
> Dou
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of bw2868bond
true does not work.
> Â
> Â
> Â
> `// Get
EpiDataView)
("ReadOnly") = True
("Enabled") = False
> End if Â
> End Sub
> Thanks for any Help
> Dou
Maybe that is the problem.
I am going to the script editor and adding the SetExtendedProps( )� after the last end sub and before the end module.
Inside the Sub InitializeCustomCode(), I am trying to call the SetExtendedProps( )�.
What would the syntax of the call be? Maybe I am using the wrong command to call it but not getting a syntax error.
Date: Wednesday, February 4, 2009, 10:02 AM
true does not work.
> `// Get
EpiDataView)
> �� edv.dataView. Table.Columns( "Number01" ).ExtendedProper ties
("ReadOnly") = True
("Enabled") = False
> `// or to make invisible�
> End if��
> End Sub
> Thanks for any Help
> Dou
