Bill, I used a 'set-field' in the Rules push the "Total Weight" to the QuoteDtl.Number01 (Set Field QuoteDtl.Number01 = decTW)and then added that field to my Quote Form. I put this rule in under Alt:.
If I run the test rules in the Config. it shows like it should work, but it doesn't populate on the Quote form.
I also tried to it thru Crystal reports. I can put the QuoteDtl.Number01 field on the report, but it only displays 0.00.
Any Further thoughts on this?
Gene
Gene
