We increased the -L parameter in the \dlcsrv\STARTUP.PF file from 5000 to
15000, and nobody could log on. We reduced it to 10000, and were able to
get the details for our 1500 part assembly just fine.
THANKS AGAIN, WAYNE!!
Sent: Thursday, May 10, 2001 8:35 PM
Subject: Re: [Vantage] URGENT!!!!!!!!!!
I just applied patch 5.00.319, and it didn't help. The -L problem happens
during the Cost Set Entry when I choose all 9,323 parts in the part master.
I guess it's a lot of records to chew on. We're in testing on 5.0 now, and
once we're live it won't be an issue for the most part.
Troy Funte
Liberty Electronics
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Thursday, May 10, 2001 9:30 PM
The 5.00.318 patch was supposed to have fixed this -L problem. Are you
running this version?
Regards,
David Sloan
IT Manager
Entech Integrated Technologies
Sent: Friday, May 11, 2001 10:22 AM
In Vantage 5.0 I've set the -L to 100,000 temporarily. I say
temporarily because if you leave it that high it will hurt performance.
After you get your job through, you may want to set it back lower. 5,000 is
the default, I believe.
Cc: tjacobs@...
Sent: Thursday, May 10, 2001 8:10 PM
At 11:55 PM 5/10/2001 +0000, you wrote:
>"Lock Table Overflow, increase -L on Server (915)"
Increase the value of the -L parameter in the startup.pf file. For
Vantage
3, it should be in DWC\DLCSRV You'll need to stop & restart the
database
service to take effect.
There's a blurb in EraNet on it at:
http://eranet.epicor.com/ansbook/vantage/public/4/46/46/46.1008mps.htm
-WC
Yahoo! Groups Sponsor
To access the Files Section of our Yahoo!Group for Report Builder and
Crystal Reports and other 'goodies', please go to:
http://groups.yahoo.com/group/vantage/files/. Note: You must have already
linked your email address to a yahoo id to enable access.
http://docs.yahoo.com/info/terms/
