This just in from Epicor Tech Support re: Time Change
I just got a response from time support:
It appears the Microsoft MSVCRT40.DLL (a "C" run-time program) which was
written to believe Daylight Saving Time is April 8th, not the first.
Using the solution below will workaround the problem:
1) Both Progress tech support and Microsoft (MS article
Q182042) confirm the error. Both are currently saying to "Uncheck Day
Light Savings on your Server and manually set the time ahead one hour. For
Report Builder reports make the same correction on the client workstation
setting it ahead an hour also.
2) After April 8th, turn on Daylight Saving Time again and
adjust the clock accordingly.
HTH,
Paul Siebers
